What is this pipe thread?
ChrisJ
ChrisJ Member Posts: 16,893
Hi all,
I need to make this part and I have no idea what the thread is yet.   It's 1" sch 40 pipe 1.05" ID but the thread is much finer than NPT.   The nipple next to it, is supposed to be 1" BSPT which I got from McMaster but it looks just as course as NPT.
Any ideas what this could be?  It does appear tapered.
  • Dave0176
    Dave0176 Member Posts: 1,178
    edited September 2020
    Electric straight threads
    DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
    NJ Master HVACR Lic# 4630
    Specializing in Steam Heating, Serving the residents of New Jersey
    https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
    https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
    I cannot force people to spend money, I can only suggest how to spend it wisely.......
  • Zman
    Zman Member Posts: 7,611
    What is it off of?
    If it is American, it may be national pipe tapered fuel (NPTF).
    The most likely import would be, British Standard Taper Pipe Thread (BSPT)
    Albert Einstein
  • ChrisJ
    NPS is the same thread pitch as NPT, no?
    mattmia2wyo
    pecmsg Member Posts: 6,387
    There is NO taper on the upper thread!
    Is that an O-Ring on the right?
  • ChrisJ
    Zman said:
    What is it off of?
    Sadly in the world I work in it's not that simple.
    I can't say what it's from, but it could literally be anything, including custom.
    I'm hoping there's a fine pitch tapered thread for pipe, though. BSPT looks way too course.
  • ChrisJ
    That's thread locker that is left behind.
    It's very clearly a tapered thread in person, the camera messes it up.
    I work in a machine shop, if I can't tell tapered from straight I need to just go home. ;)
  • Zman
    Hmm,
    Do you have a pitch count? You may need to break out the gages and look through countless charts...
    Albert Einstein
  • ChrisJ
    Zman said:
    Hmm,
    That's what I'm hoping to avoid.
    Luckily it doesn't need to be exact as I'm making both pieces but I was hoping it was a common thing.
    Oddly enough I count 14 TPI by eye, which is the same as 3/4 NPT but not 1".
    Jamie Hall Member Posts: 26,272
    I just have to wonder... is it metric, by any chance?
    mattmia2 Member Posts: 13,859
    Is it an adjustable die for 1/2 and 3/4" that was made to cut 1" thread?
    It doesn't look like the angle or geometry of the groove is the same as NPT either. There was some sort of fine pipe thread in the US as well I think. BSPT is a different angle than NPT if I recall, but this is probably neither. Is there any reason to believe it wasn't something someone just cut on a lathe to connect the 2 parts?
  • Matt_67
    Matt_67 Member Posts: 309
    My guess is metric taper - maybe M33 x 2.0?
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    NPS is a straight thread.
    Steve Minnich
  • ChrisJ
    It's straight and as far as I know it's the same pitch as NPT.
    EBEBRATT-Ed Member Posts: 18,382
    I know what it isn't and it's not a conduit thread.
  • BillyO
    BillyO Member Posts: 277
    lets see die you used to thread it. why are we guessing at this?
  • ratio
    ratio Member Posts: 4,094
    Hmmm…
    CanuckerZman
  • psb75
    psb75 Member Posts: 1,055
    BSPT-- British Standard Pipe Thread is straight, not tapered.
    NPT-- NationAL Pipe Thread is tapered.
    In the picture: the top pipe looks like straight thread.
    The bottom fitting from McMaster (close nipple?) looks like tapered NPT.
  • ChrisJ
    psb75 said:
    BSPT-- British Standard Pipe Thread is straight, not tapered. NPT-- NationAL Pipe Thread is tapered. In the picture: the top pipe looks like straight thread. The bottom fitting from McMaster (close nipple?) looks like tapered NPT.
    BSPT is British Standard Pipe Taper
    You're thinking of BSPP which isn't tapered.
  • psb75
    You are correct. My bad. BSPT is British Standard Pipe Taper and BSPP is British Standard Pipe Parallel (straight threads).
    I've encountered BSPP threads on Myson panel radiators. I've even used NPT fittings on them with pipe dope and MANY wraps of tape. They did seal.
    I'm guessing this is the die that was used to thread it:
    https://i.ytimg.com/vi/sYfHedtUsCs/maxresdefault.jpg
    ZmanEdTheHeaterMan
  • ChrisJ
    mattmia2 said:
    I'm guessing this is the die that was used to thread it: https://i.ytimg.com/vi/sYfHedtUsCs/maxresdefault.jpg
    That's a cute little thing :)
