best combustion gas analyzer to buy need advice
mikedo
Member Posts: 274
I'm looking to buy one any advice what i should get. thanks mike
testing gas heating and hot water equipment. I'm not going to use it much I'm more of a plumber. but id rather buy something thats going to last even if its a little more0
One thing to be aware of with just about all of them: the O2 sensor has a SHELF life of two years and it's not cheap. It will also fail without warning and usually at the least opportune time. Having a spare on hand does no good, because again, it has a shelf life whether it's installed or not.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.3 -
I'll second the E Instruments. I've had one for about 10 years with no issues but the O2 sensor and maybe a charger.Bob Boan
Testo 320 is definitely a favorite for HVAC technicians who use it a lot. The Testo 330 is the latest and greatest offering from Testo. But since you say that you aren't going to use it a lot the Testo 310 would probably be a better option, it still performs well, I just don't like the black and white display as much. I also found it took a little getting used to after having only used the 320. But the 310 is more affordable, as are the instruments from TPI.0
Testo 320 for me, but like others have expressed, I have only used a Wohler, and a UEI. Testo in my experience was better.Tom
Montpelier Vt0 -
i was looking i think the 320 is discontinued0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
