Install In Progress-The Show Must Go On
Weil EG75. Replacing (of course!) a Burnham IN.
New England SteamWorks
newenglandsteamworks.com
Dave0176PrecaudHap_Hazzardkcoppethicalpaul
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    That thing should have a keyboard on it. :D
    BobC
  • JUGHNE
    JUGHNE Member Posts: 11,547
    I'm jealous as I have only worked on handicapped/knucklehead existing systems, making the best (hopefully) of what is there.
    Where did you get the idea for dropped manifold tree water seal for controls and gauges?
    EBEBRATT-Ed Member Posts: 20,145
    Used to be common with large commercial boilers (where you need a ladder to reach the controls) to put the high limit on the boiler then pipe over to the wall and down to 5' off the floor and mount the operating and modulating controls on the wall.
  • retiredguy
    retiredguy Member Posts: 1,090
    WOW, that is a picture perfect installation but where are the cast iron fittings. (just kidding) I also like the aluminum pipe wrench with the optional bent handle indicating a cheater handle that every good pipe fitter has at his disposal. If I was looking for a job I would come see you. You have pride in your work.
    New England SteamWorksmattmia2
    mattmia2 Member Posts: 16,683
    What are the multiple I assume king valves for?
  • Hap_Hazzard
    You need to shut off all the risers to do a blow-down. They also come in handy for isolating risers while troubleshooting balance/distribution issues. Every riser should have one.
  • New England SteamWorks
    New England SteamWorks Member Posts: 1,529
    We’re getting there!
    STEVEusaPAPrecaud
    Steamhead Member Posts: 18,468
    Wow. Just....... wow.
    Consulting
    pecmsg Member Posts: 7,043
    Raising the bar to a higher standard that should be followed!
    Cheers!
    Very nice! Exceptional is the word.
  • SuperTech
    SuperTech Member Posts: 2,661
    Wow. That looks like art to me. The first thing that comes to mind seeing that installation is that it's proper. Flawless.
  • STEVEusaPA
    Awesome as usual. How many man hours just for the pipe insulation? Jus wondering.
  • Intplm.
    Intplm. Member Posts: 3,005
    Always a great job. Clean. Really clean. True Plumb and level as they say.
    Excellent work !
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,315
    I wonder how that would work with that big column of water sitting on top of the pressure control. It would throw off the pressure control 1 psi for every 28 inches of water stacked up above.
  • retiredguy
    Clever Brooks and a few others use that drop down trap for the pressure controls on their package boilers. For high pressure boilers, that 1# for every 28" makes almost no difference when the pressures are 100# and above. I always hated working above a boiler especially in the summer due to the heat, so a low mounted limit was a welcome change.
    HVACNUT Member Posts: 7,425
    I know pipe insulation is a good thing but it's like covering the Mona Lisa.
    Excellent job!
    unclejohn
  • jerryb46
    jerryb46 Member Posts: 60
    the picture at the final shows pride in the artist's work,its good to see that there is still some careing about how you do a job,WELL DONE!!!
  • lchmb
    lchmb Member Posts: 2,997
    simply beautiful... god I miss install work...
    ethicalpaul Member Posts: 8,749
    You're hurting your 2027 sales volume!!
    SuperTech
