Been a very quiet year so far
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Does anybody do swimming pool plumbing in the spring & summer? That seems like it would be a good sideline for the off season.Just another DIYer | King of Prussia, PA
That's unfortunate, what do you do to fill your time? I got 4 boilers and 17,000 sq ft of radiant tubing installed in January and then broke my ankle snowmobiling early February, still 3 more weeks until I can walk but I've got almost 30,000 feet of tubing and 11 more boilers sold when I can get moving again, the boom never really stopped around here. I only do radiant and I only work weekends (fulltime elsewhere) so it's a bit of a niche market.0
Looks great @Dave0176 !
Was the old boiler in a hole? Or was that hole in the floor patched long ago? Do you usually put your boilers on blocks or set them on the floor? Mine is on blocks but I have no idea why
I find that from now til they light the wick on the summer craziness, I try to fit in all the clean and tunes I can. Then they are done.Tom
Montpelier Vt0 -
Could have been to raise the water line if you had some drips that would have ended up above the new water line.
Probably most likely to just get the boiler off the floor in the event of wet floor.
I put all tanks and boilers up on at least 4" thick solid blocks.
Sometimes called equipment pads or housekeeping pads.
2 -
Oh, there was a boiler that was there before the floor at some point.
The blocks are great to help keep the boiler(or other equipment) off the floor a bit and keep it from getting damp or wet from moisture or leaks/backups in the basement.
I put my indirect on blocks so I could put a pan under it and have the pan be uphill from the floor drain. The floor sort of slopes away from the floor drain...0 -
I’d say the boiler was installed before the basement floor was poured, because under the boiler was the dirt floor.ethicalpaul said:Looks great @Dave0176 !
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
Well it’s either that or thread your own nipples, which is time consuming. I have the nipple chuck for when it’s needed though.ratio said:That's a heck of a nipple kit to carry around!
I cannot force people to spend money, I can only suggest how to spend it wisely.......2 -
Air Conditioning will be starting up, I have three replacement jobs in que, and multiple condenser cleanings which usually start around the second week of April, the last couple years no because it was so cool, but we'll see what this springs brings.Hap_Hazzard said:Does anybody do swimming pool plumbing in the spring & summer? That seems like it would be a good sideline for the off season.
Yes first 90 degree day and all hell breaks loose. Then suddenly everyone wants me to go up in their unventilated attic’s, lol.Tom_133 said:I find that from now til they light the wick on the summer craziness, I try to fit in all the clean and tunes I can. Then they are done.
I cannot force people to spend money, I can only suggest how to spend it wisely.......3 -
Some late start new construction projects have been keeping us busy. New construction is rare around here. Almost as rare as boilers. Been the mildest winter I can remember since moving ot Iowa in 2004. Been slow otherwise.
You probably already know this, but pools use heaters or heat pumps, and they need maintenance. When I had to repair my heat pump, I had a hell of a time getting the manufacturer to sell me parts. They wanted me to call a "qualified" service technician.Dave0176 said:Air Conditioning will be starting up, I have three replacement jobs in que, and multiple condenser cleanings which usually start around the second week of April, the last couple years no because it was so cool, but we'll see what this springs brings.
This.EBEBRATT-Ed said:@Dave0176
Nice job as usualAll Steamed Up, Inc.
Consulting0 -
Really a beautiful job,
Why no pipe insulation on the new work.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Very nice Dave!
Warm weather means steam boiler block corrosion not readily apparent. Symptoms resemble normal make up water amounts....
Those jobs aren’t gone.
They are just sleeping.
Waiting for the next Polar Vortex.New England SteamWorks
newenglandsteamworks.com0 -
Could you elaborate, please - why not readily apparent?New England SteamWorks said:
Warm weather means steam boiler block corrosion not readily apparent. Symptoms resemble normal make up water amounts....1950 Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.
> @Fred said:
> @Precaud , he probably means during warm weather the heat cycle isn't long enough or frequent enough for an abnormal water loss (above the boiler water line) to be apparent.
My Burnham V8 was losing water just doing domestic hot water all summer long.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I can see that happening. I was thinking heat only in the winter months. It would be more obvious when the boiler also provides hot water for the household.ChrisJ said:
When it’s really cold out the boiler is running constantly and any leak will require constant additions of water. When the temp drops below 20 the phone rings off the hook around here with “We constantly have to add water to our boiler”.New England SteamWorks
Little update, just went through the last 10 days with Coronavirus and I’m now starting to feel better, however could still be a few more weeks before I can work because of still being contagious. Thank god it wasn’t a severe case. Was very tough to breath for about 7 days, thought about going to the hospital a few times but I was able to weather through it. Been stuck in my bedroom with My wife basically taking orders and leaving stuff on the floor in front of the door. Can’t wait till it’s over.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
Wow Dave I'm glad you were able to get through it without going to the hospital!
We need you Dave! Get well and get back!New England SteamWorks
newenglandsteamworks.com2 -
Fred said:
Get well soon @Dave0176 !
ethicalpaul said:Wow Dave I'm glad you were able to get through it without going to the hospital!
Intplm. said:@Dave0176 So glad to hear you are on the mend. Hope its over for you soon.
Hang in there.Intplm. said:@Dave0176 So glad to hear you are on the mend. Hope its over for you soon.
Hang in there.Erin Holohan Haskell said:I'm so glad you're ok, @Dave0176.
Precaud said:You're an artist with the pipe, glad you're still with us.
These!New England SteamWorks said:We need you Dave! Get well and get back!
Consulting2
