Yoga Pipe
Weed wakers, U-V resistant?, Pressures,fastening system. Approvals?
Whats your 2 Cents? How did this make it into the trade
50 year life expectancy? Don't think I would bury it in a wall.0
Why?Jolly Bodger said:50 year life expectancy? Don't think I would bury it in a wall.
Mr. McGuire said it in 1967!
https://www.youtube.com/watch?v=Dug-G9xVdVs
The life expectancy of copper is generally considered 50 years as well. Copper also doesn't resist nails very well either. I suspect that's where their number comes from. It doesn't necessarily mean it won't go 100+. That said, with the average life of the garbage equipment being installed and musical refrigerants I don't see it being an issue. A new lineset will probably be run within 15-20 years.Jolly Bodger said:@ChrisJ Why the limited life expectancy? What causes it to degrade?
Also: nails.
I'm not saying I'm for plastic refrigeration piping and linesets.
But, as of right now I also do not see any actual problems either which is why I asked.
2 -
@ChrisJ and those are reasons I would try to not bury a lineset at all. I agree that Tech progresses and equipment does not last. I will let others be the guinea pigs and join in when it becomes a time tested tech. polybutene pipe and aluminum wire come to mind.0
Aluminum wire is perfectly fine and used all around us. Look up at any power lines around you.Jolly Bodger said:@ChrisJ and those are reasons I would try to not bury a lineset at all. I agree that Tech progresses and equipment does not last. I will let others be the guinea pigs and join in when it becomes a time tested tech. polybutene pipe and aluminum wire come to mind.
Improper installation procedures is what caused the failure in home wiring.
I cannot blame you for waiting.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
@ChrisJ Yes, Aluminum wiring is good for feeders but not allowed for branch circuits. I agree, install and application make a big difference.0
https://www.yogapipe.com/pecmsg said:> @BDR529 said:
> Seen it in new construction. Good Gawd man! In short PeX for refrigeration
Got a link?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
@ChrisJ Remove and Reinstall.0
So true..EdTheHeaterMan said:Mr. McGuire said it in 1967!
Handy homeowner loves these new products!
Yes, it's not like the propress or pex industry isn't booming with contractors eh? And we all know everyone is running cast iron for drains....... Only handy homeowners are running easy PVC........
I'm all for these threads if they're about sharing facts and experiences and are kept respectful.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
3 -
No, the problem is not just the handy homeowners as we know.
Have seen the line set taken out with the weed wacker. Thats not the only guy with a trimmer and/or landscape company.
It is undoubtedly about the price of copper...0
Apparently they didn't read the part of the manual about arranging the lineset so that the oil returns to the compressor...
https://www.yogapipe.com/yogapipe/images/YogaPipe_ACR.jpg0 -
Depends on the velocity through the suction line.mattmia2 said:Apparently they didn't read the part of the manual about arranging the lineset so that the oil returns to the compressor...
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
