Another IRONMAN Header
Ironman
Member Posts: 7,731
This job is a remodel of an old Victorian with a new addition. The upper circulator serves the old section which has a monoflo loop and CI rads. The new part will connect to the Cross manifold and it has a combination of CI rads and new Baseray.
We did enough to get the boiler fired off to heat the indirect. More pics and info to come.
Bob Boan
2
Are you using 2 or 3" Bob?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
How do you like the Cross manifolds? Never seen those.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
I tried to get the HO to paint it black to no avail.Bob Boan
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
This is the second job we've installed them on, but haven't fired them off yet.Solid_Fuel_Man said:How do you like the Cross manifolds? Never seen those.
They're easy to install, my only complaints are that they don't offer the connectors in 5/8" and you can't swap the supply and return manifold positions. You can rotate them, but not swap.
Bob Boan
Looking good! I just geared up for a similar setup this afternoon, UFT-100W and SSU-45 going in a 3 zone radiant shed/house combo with Cross manifolds.
Side note: Someone pointed out to me awhile ago that on page 18 of the manual it states that only brass, copper, or SS fittings can be used in the system- which is funny given they provide black fittings for the relief. Ever get any grief on that?1 -
I've never heard of that, nor can I find it in the I/O manual.GroundUp said:Looking good! I just geared up for a similar setup this afternoon, UFT-100W and SSU-45 going in a 3 zone radiant shed/house combo with Cross manifolds.
Bob Boan
Page 18, in one of those shaded boxes in the upper left that nobody ever reads. Says something about dielectric unions and galvanized fittings voiding the warranty, then follows up with brass, copper, or SS only. I don't have it in front of me at the moment but I know it's on page 18. Kind of a poorly worded statement like several other things in the I/O but I'd have a hard time believing they'd void a warranty over malleable fittings. Worth taking a look for yourself and see what you think0
I just read that part in the manual and states nothing about the use of black pipe and fittings voiding warranty just says galvanized fittings and dielectric unions.0
Love the piping ... So you make up your own LLH ? What's the line going out of the top of the LLH?
How do you like the HTP? -- I have to pick a boiler soon (propane)0 -
Makeup water and vent.TAG said:Love the piping ... So you make up your own LLH ? What's the line going out of the top of the LLH?
Bob Boan
You like the HTP boiler / indirect set up?
Wish I could find someone in bucks county PA0 -
Got it .... Although sometimes things get specified. Seems everybody has a reason to love or hate the same boiler. In my area most of the installers seem to have moved from Viessmann -- because of unresolved warranty issues.
So I'm looking for another make.-1 -
No more pictures ... ? I like the setup ... are you adding mixing motors or are they static valves.
The manifolds are cool -- a bit expensive. I'm not sure if they will give me anything with my new house mostly warm board0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 987 Plumbing
- 389 Solar
