Weil-McLain's Famous Glass Piped Steam Boiler Fired Up at EEE 2019
Gordo
Member Posts: 857
Weil-McLain's well known glass piped steam boiler is fired up at EEE 2019 in Hershey PA.
My thanks to the W-M demonstration crew for letting me film this.
Dan Holohan makes a cameo appearance at the end of this video.
https://www.youtube.com/watch?v=J5mzrLlIHbY
3
a great training toolgwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
Resting until the next gig on LITo learn more about this professional, click here to visit their ad in Find A Contractor.0
When is that @Robert O'Brien?0
May 30 at BlackmanTo learn more about this professional, click here to visit their ad in Find A Contractor.0
Looking at that, I’m glad I added generous amount of slope to my drop header. My old boiler “got by” because it had a fairly large internal volume (HB Smith G300) and was performance limited by mud in the sections. I think he newer lower mass, lower volume boilers really need oversized drop headers. 3” pipe ain’t cheap, but it only needs to get installed once. Most replacement boilers after that should pipe right in with only minor piping changes and if same brand, dimensions likely won’t change much over the next 40 years.0
Is that firing at the rated BTU or do they overfire the heck out of it to get it to boil that high?NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el1
Wow, that surprises me! Would that be considered wet steam? Or is it more of a continuum, as in "that steam would be dryer if it went through a drop header, but it will do OK"
How wet is too wet?NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el1 -
When you look at photos of this (I have those in The Lost Art of Steam Heating Revisited), you can see the invisible dry steam in the top of the header. It's just the nature of modern steam boilers to do this. One of the things that made old steam boilers relatively inefficient was their massive size. This is why we must consider proper near-boiler piping a part of the boiler nowadays. The W-M boiler with in the video is clean and perfectly piped. I've been watching that beast perform for decades. W-M has done a great service for the industry in building it and sharing it so generously at the shows.Retired and loving it.3
I couldn't agree more, it's a great way to see what is normally only guessed at.
I'm just struggling to understand wet vs dry steam. If this boiler with this piping is producing dry steam, then I can't imagine what wet steam would look like. I'll go look again at LAoSHR. Thanks!NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el1 -
You'd probably hear it before you saw it...ethicalpaul said:... I can't imagine what wet steam would look like...
Over the years, I've filmed this glass boiler firing several times, but I believe this is the first time I've gotten a good shot of what is going on directly inside the boiler. Usually, the MW crew is doing this demo for an audience and I don't want to be obnoxious and interfere with their presentation while getting close-ups of that window into the boiler.
This time, they very graciously fired up the boiler just for the film above because I assured them it would be given the maximum dissemination that I could muster. Having Dan in the video was an extra bonus!
The contrast between the violence going on inside the boiler and the almost serene gentle bobbing of the waterline in the sightglass is worth noting.
I think in the past they used to add a teaspoon of oil to show what happens. Splooosh!All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
I have some from 25 years ago.
It will be at Blackman in Bayport on 5/30 for any Lawn GuylandersTo learn more about this professional, click here to visit their ad in Find A Contractor.0
I never get tired of seeing this. It is one of the best real life visual effects I have ever seen.
Kudos to @ethicalpaul for doing a "mini" version of this on his own boiler👍🏼2 -
@Gordo - Thanks for filming. Can we share this in the Systems Help Center too?
President
HeatingHelp.com0 -
@Erin Holohan Haskell - Please, I would be honored.All Steamed Up, Inc.
Thanks so much!Gordo said:@Erin Holohan Haskell - Please, I would be honored.
President
HeatingHelp.com0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
