Best spot for a steam radiator in a small room
branimal
Member Posts: 259
I'm renovating a building and I need to choose a spot for a radiator in small room. The most important thing is the radiator doesn't affect furniture place / usability of the room.
It has to go along the wall with the windows.
Options are:
1. under the window b/c people typically don't put furniture in front of the window.
2. In the weird angled corner
3. In the 90 degree corner.
Any thoughts?
Options are:
Any thoughts?
Mercy. That's not a room, that's a closet. From the standpoint of heating the room, it really won't matter -- radiators circulate warm air (naturally) pretty well. From the standpoint of using the room, though... although option 1 is conventional, I think it's problematic, as that is where someone will have to walk to get into the corner. On the whole, I think I'd go for option 2, and put some sort of clever set of shelves over it, starting about a foot above it....Br. Jamie, osb
yeah its legal. 7 feet in a building with 3 or more bedrooms is legal. The other bedrooms are standard size.0
The only place left for someone to put a typical dresser is in front of the window so option 2 is really the only option, by the numbers.1
Thanks guys.
Danny - good idea on the riser. The pipe coming up is 1". I'll google heat loss calc and get back.
Mike - it's single pipe steam system.0 -
How do you plan on controlling the heat in that closet?
Only 2 outside walls, well insulated there wont be much heat loss, any calculations on the total BTU's required?0 -
You need to do the heat loss on all the rooms. I’ve read some of your other posts and this is like a new system with all the work being done. Room by room heat loss, size the radiation accordingly.1
There was a post here where the guy made his own radiator in the bathroom, very small.
Maybe the microtube system0 -
4. mount on ceiling 5. recess into wall 6. install in floor box between joists.0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
