Steam boiler replacement
Dave0176
Member Posts: 1,177
2007 installed Burnham V84, owner wanted to replace it to convert to gas, however while removing the boiler we found the rot starting on the middle sections. It was a good time to do it as next winter it would’ve probably let loose. We went in with a Weil-McLain EG45. The mains are split one side being 1-1/2” and the long main 2-1/2” of course the old near boiler piping left much to be desired. The oil companies were great at servicing and leaving their tags however they never really cleaned this boiler very good as you can see from the pics.
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
1
And the oil companies wonder why they always lose business......
Looking great so far!All Steamed Up, Inc.
Consulting2 -
Neglect. The owner should write a book "how to ruin a 12 year old boiler"0
Bit more progress.
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
looking good!! Sad to see the old boiler in that condition. I am curious though, why the double drop?0
That main starts off as a counterflow.lchmb said:looking good!! Sad to see the old boiler in that condition. I am curious though, why the double drop?
that explains that.. thanks!!0
For the Hartford loop, are you just using a Y strainer and removing the strainer basket? I Haven’t seen any plain Y fittings anywhere.0
My supply house gets them in on my request, not cheap however. These are made by Anvil, Ward doesn't manufacture them anymore.mikeg2015 said:For the Hartford loop, are you just using a Y strainer and removing the strainer basket? I Haven’t seen any plain Y fittings anywhere.
Or the servicer shouldNJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0 -
The HO just bought the house last August. The PO did have the oil service contract, just unfortunate that a lot oil companies techs don’t do good job.EBEBRATT-Ed said:Neglect. The owner should write a book "how to ruin a 12 year old boiler"
Did an amazon search. Holy hell $111 for a 2” wye. I’d feel compelled to paint it gold after installation.
Local supply can probably order them for less than that... maybe.0 -
And in this case, as in millions of others, they lost the customer as a result. The gas guys don't even have to try- the oil guys are handing them new customers on a silver platter.Dave0176 said:
Consulting1 -
@Steamhead & @Dave0176
Can't even guess how many wet base boilers I have seen with the firebox full of soot and never cleaned out, especially the older stuff and larger commercial stuff Smith 28, Weil 88, Burnham etc that don't have swing out doors.
I mean, come on you brush the boiler where do they think the stuff goes? It's in the chamber.
I mean on the ones that burn clean and have difficult access you have to pull the burner or get in their every 3 years or so.......not every year just lazy. Flue pipe is the same thing, gotta check it once it's clean every s or so is ok if combustion is good0 -
She’s a crusty one Mr Grinch! Nice clean install as always. What a shame a 12 year old boiler got wrecked from lack of maintenance.0
The HO sent me some pics he took of us .... here is my 67 yo pop still putting in steam boilers. I don’t know what I’m gonna do when he can’t do this anymore. These kids today
won’t work this hard.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
More work completed, replaced over 50’ of return piping and temporarily test fired the boiler. Getting there.......
I cannot force people to spend money, I can only suggest how to spend it wisely.......2 -
Dave, I love that jank power hookupNJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el1
I'm also in NJ, no it is not code nor required to use cross tees on residential steam boilers for control piping. However, it is certainly a nice touch and pretty much guarantees the standard 1/4 inch pigtail will not get clogged. Dave goes above and beyond most of his competition.0
@JUGHNE
Yup, that's the one. I get a kick out of that guy. He does some hacky stuff but after you watch a bunch videos you can't deny that he is a hard worker and he is no dummy. Some things are **** backwards though.
@ScottSecor
every place is different, I think the crosses are an ASME thing. Probably not required on residential although a good idea. In MA everything over 200,000 input is considered commercial unless installed in a house. Then they want man reset high limits on HW & Steam 2 LWCO on steam (1 with reset) and a LWCO on hot water, emergency switches outside all boiler room entrances.
At one time in MA all the 1" piping below the water line on low water cutoffs used to have to be brass but they dropped that1 -
I have used the cross tees on boilers that have multiple devices.
Each gets it's own 1/4" SS or brass long riser nipple off of the 1/2" black manifold.
If the lower black piping is clear each year then the 1/4" risers are most likely clean.0 -
He's sure no steam man thoughNJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
@ethicalpaul that's for sure, cut and slide0
@JUGHNE
When I started I "73" all of New England, ME, MA, CT, VT, NH,RI was 80% heated by oil. I am sure it's no where near that now but still remote areas that will probably never get natural gas. Still a lot of oil around here though1 -
***** 5 Stars. Really sweet!New England SteamWorks
newenglandsteamworks.com0 -
> @EBEBRATT-Ed said:
> @Mike Cascio
> I think you have been watching too much Steve on You Tube LOL
I suspect a lot of people watch Steve Lav on this forum! I watch it with my coworkers for lunch entertainment. We call it putting on some leakas!1
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
