Electrician gouged heating pipe - Should I be concerned?
jcwacky
Member Posts: 2
Had an electrician round to fit an extra socket in a bedroom this morning, we have the carpet up so he routed it under the chipboard floor, but looks like he slipped with his hole saw at some point as there's a clear gouge on the 15mm pipe to the radiator.
The heating (pressurised to 1.5 bar) is on and there are no leaks, so it's not gone all the way through.
From these photos should I be concerned and ask him to arrange a plumber to come and apply a fix? Or is it no cause for concern?
I don't see anything to be concerned with.0
If it was my place I wouldn't worry about it.0
I've seen a lot worse... not to worry, I think.Br. Jamie, osb
Judging by the first picture the length of that scar it looks fairly deep to me.
I would leave it as is and document it with the electrician and show him pictures keep copies0 -
Thanks all, that's extremely helpful!
I'll take on board all your comments and leave as is but look to ensure it's documented with the electrician.
I'm about to ply over the floor in preparation for LVT flooring, so may even add a Rothenberger as a backup (I know they're just meant to be temporary).
@Ironman That's Wimpy in 1998 for you!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
