See wet steam in the wild
https://youtu.be/Si-FoRQVIpA NJ Steam Homeowner.
Free NJ and remote steam advice:
https://heatinghelp.com/find-a-contractor/detail/new-jersey-steam-help/
See my sight glass boiler videos:
https://bit.ly/3sZW1el
Yes I’m sure the single tapping isn’t helping. I was warned about that way back when I first came to HH. But 2” is full size.
Why does all the water almost disappear sometimes? Like around 8min in?0
Great question, @SuperJ , I noticed that too. It could be pressure or water level changes that settled down the boiling for awhile, or it could be something to do with the movement of water or steam between the sections of the boiler. Not sure!
I guess I made the assumption that it had thrown enough water up into the main that the water level in the boiler was low enough to minimize throwing much more into the side tapping, at least until the water returned back into the boiler.
It would be interesting @ethicalpaul if you noted the water level in the boiler when it reaches the point of little or no water in that riser and started the boiler with that amount of water in it and see if it still throws water into that riser.2 -
what does your waterline in the regular sightglass look like during all this ??0
Not bad. I aim the camera at it briefly during this video. It moves but nothing crazy (but I only know my boiler so take that with a grain of salt)
I see a lot of those Utica and every other brand piped wrong even w the video I doubt it would change the ho mind as to why they have unfixable issue s unless u correct the near boiler piping .i believe Fred is right on the wEt steam halting at some point it seems when lower the water line bout 1 inch or so on those Utica’s the sight glasss and boiler behave a little better It just seems to be imposssible that no one would pay extra for the right job but I guess people love drama and having a issue to complain bout is a major thing these days so instead of complaining bout neighbors ,kids or wife u can complain bout your steam boiler and crappy heat blame it on the whole steam heating industry or pay the higher price and get the right job or live and complain Not to be a **** but didn’t need the glass pipe to know u making wet steam just go to the lash and do the math Paul I have to admit love your stick to it ism peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating1 -
I dumped about a gallon which was about an inch lower for resting water level and now no boiler water appears in the riser during boil. Just a very small amount of condensate coming back.
I was at 24” above the bottom of the boiler, about 3/4 in the glass. So now I’m about 1/2.
I was at 8 ounces during the video but without the water in the riser it’s running at about 2 ounces on the gauge!NJ Steam Homeowner.
Dang. Mind if I use this video to show people what happens when you have improper piping/water level? I've had a couple clients that think the water should be right to the top of the sight glass.0
Absolutely! Anyone can use it for any reason!
I think with steam there is an art to dialing steam heat in since every system has it's own temperament. You have to find the correct waterline that works with the header, the operating pressure that works with the mains and the vents, the correct vents for the mains and the radiators, the correct pitch for the pipes and the rads. I actually found myself tracking down a water hammer with a long screw driver like I used to do to diagnose problems and tune an old water cooled car engine I had that people don't know how to fix anymore.
The problem is whoever you have come to fix it is there for an hour or so and likely has limited knowledge of steam so is just doing whatever the text book says which is also likely wrong. There are very few people in the trade that actually know what they are doing, I am happy to have found one of they few.
@ethicalpaul there are very few people who would have thought to lower the water line to solve your problem. I had the same experience, couldn't see the water in the risers but could hear it. I lowered the water level, chocked down the autofeeder, massed out the venting to lower the operating pressure and the problem was solved.
I think your experiments and visuals like this are really helpful for non professionals on this site to actually understand what is going on inside their boiler.2 -
Very informative. I knew something like this was happening in my wrongly piped boiler, but more from hearing than seeing. So when you lowered that water level an inch were all your radiators still heating adequately? It shows that even a flawed system can be improved if you have a handle on what is going on, because many of us have to work with the installations we have, and not the ones we wish we had.0
So cool. Did you get the parts machined locally?0
I like your sight glass, that's pretty cool. I want one for my hydronic boiler, it's got me thinking about how to do it...
Why does your boiler water look so nasty? Don't you flush your boiler out every once in a while?0 -
It’s Rectorseal 8-way to keep the ph up (which if too high can exacerbate this situation so I’m still dialing in the right amount)
No, they are a readily available fastening system called tri-clamp. Used in brewing, etc.
2-1/2"Sanitary Sight Glass Tri... https://www.amazon.com/dp/B07J67MFBF?ref=ppx_pop_mob_ap_shareNJ Steam Homeowner.
Yes. The steam is fine. I was running that level or lower for a year.NJ Steam Homeowner.
I guess there are NPT adapters of some kind for this fitting?ethicalpaul said:> @amitjm1980 said:
2-1/2"Sanitary Sight Glass Tri... https://www.amazon.com/dp/B07J67MFBF?ref=ppx_pop_mob_ap_shareContact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Yep for sure, in all sizes: https://www.amazon.com/gp/product/B073B1Q9TH/ref=ppx_yo_dt_b_asin_title_o04__o00_s00?ie=UTF8&psc=1
See my earlier post where I installed a smaller one on my return line: https://forum.heatinghelp.com/discussion/168004/sight-glass-on-main-shows-a-surprise#latestNJ Steam Homeowner.
What inspired you to do this? Go to all that trouble?
Have you seen the videos of the see threw working steam boilers? Bet you have.
I gotta say this is an excellent visual ! Nice video. @ethicalpaul Thanks for showing it.1 -
I was just really interested to see what was going on in there
I did see that WM video with the big demo boiler on a trailer with the glass header and I'm sure that was an inspiration.
The first step was the little glass on the return...that one was super easy--the glass was about the same length as a nipple that was above a union in the drop to the wet return, so it was an easy swap. Then when I saw there were times that boiler water was running down it, I had to have a look at the main's riser!NJ Steam Homeowner.
Grallert said:
Thanks for those videos. really cool to watch. Almost makes me want a steam system in my house.
You can have one!NJ Steam Homeowner.
@ethicalpaul thanks for the videos.
Your boiler water looks pretty nasty, when was the last time it and the boiler and returns were flushed? Water quality issues can add to wet steam.0 -
Saw the title thought of this........ wet steam in the wild.
https://www.youtube.com/watch?time_continue=19&v=LWrklFuYnb02 -
Hats off to @ethicalpaul. Makes one think. Why shouldn't these be mandatory on all boiler installations?3
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
https://youtu.be/IjPLN2NO2n8
