glycol
inspkerr
Member Posts: 35
Hello, We are expecting record low temps in Minnesota this weekend. I have a system with Propylene glycol in it that has been tested to -25 . we are predicted to have temps of -30 -35 these are non-windchill i know i probably could not pump this fluid at these temps but could it rupture piping or equipment or radiators
It won't if it stays hot and circulates.0
Thanks Alan, Its not operating and will be subject to said temps0
Cross your fingers. Usually not, but... Can't you turn it on?Br. Jamie, osb
THANKS guys , I can't turn it on,Its at very remote location,I have heard that it would just get slushy when it get below the the tested temp,I'm trying to decide to make the trip to start the system.0
The glycol will not crystallize, so any pressure increase should be felt at the expansion tank, & therefore reduced.
Having said that, I added glycol to 25% in my system for the last week of so that I ran it, then blew it out when we left so that any liquid left in the system should turn to slush in case I was not able to get every bit of liquid out, esp at the boiler and pump.
If we leave again next winter I will probably repeat that process.0 -
Thanks for your thoughts, I did just test to -25 last month after running the system, Nat. Weather service says -29 for my area Tuesday . I have cast iron radiators connected to P.E.X. with weil Mclain GV3 I'll be putting in a remote start system through my phone line next year for sure,not going through this again0
You do realize that wind chill is irrelevant in this case, right?inspkerr said:Hello, We are expecting record low temps in Minnesota this weekend. I have a system with Propylene glycol in it that has been tested to -25 . we are predicted to have temps of -30 -35 these are non-windchill i know i probably could not pump this fluid at these temps but could it rupture piping or equipment or radiators
3 -
Yup, aware of the wind chill versus ambient Thanks for your input!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
