Oil has more heat per BTU? Is Bob Vila wrong?
I was reading up on energy costs for different fuels - trying to work out a price per BTU conversion factor since energy is sold in a bunch of different units (gallons, kWh, cord, pallet, pound, whatever) but that's another topic. And I came across this write up on Oil vs Gas. https://www.bobvila.com/articles/gas-or-oil-heat/
The thing that made me scratch my head was this: "Oil equipment provides more heat per BTU than other heating sources" ...and ...."as provides less heat per BTU than oil"
I thought a BTU was BTU. Am I missing something?
Just trying to learn what I can do myself and what I just shouldn't touch
You aren't missing anything, a BTU is a BTU doesn't matter what you are burning, oil, gas, paper, hair. Plenty of misleading information on the web like this.3
Weird, perhaps it about the difference between in and output BTUs (or efficiency).
Yes, a BTU is a BTU, but different heating systems waste them in different ways.
The author is a furniture writer, not a engineer or HVAC pro.
https://www.bobvila.com/authors/Donna-Boyle Schwartz
I think she means that oil is more energy dense than natural gas, which is kinda true.
Which is heaver a 1 pound hammer or a pound of feathers?0 -
Ah, OK. The article meant to imply that oil furnaces are efficient. it seems obvious now that you suggest it. Duh.New owner of a 1920s home with steam heat north of Boston.
Just trying to learn what I can do myself and what I just shouldn't touch0 -
I take that back... two lines earlier in the article it says "Natural gas furnaces have higher heating efficiency and their fuel costs less" .New owner of a 1920s home with steam heat north of Boston.
They're describing the energy density of the fuel. I believe a gallon of oil has more available BTU compared to a therm of NG but it's useful for comparing fuel costs. Your building needs what it needs for BTU, as you notedYou can have it good, fast or cheap. Pick two0
Maybe it’s the 140000 Btus per gallon versus the 100k per gas therm he is referring to?0
As Colonel Potter would say: He is full of horse poo poo. A BTU is a BTU. Here, we use one liter of #2 oil is equivalent more or less to one cubic meter of gas input.0
In the past when I worked at an oil company we used to preach that gas was less efficient than oil.........and it is and was. It has to do with the water vapor content in the gas. It took energy to "boil" the water vapor.
NOW this has all changed. It changed when boilers and furnaces were designed that became condensing. Now that the gas water vapor can be condensed the energy used to boil the water vapor is recovered and gas is more efficient than oil.......when condensed0 -
I think I might like her less than Bob Vila and that is hard to do. Who let an interior decorator write an article on heating?
Here is the real deal on energy costs."If you can't explain it simply, you don't understand it well enough"
Albert Einstein2 -
Oil has more btus than a gallon of propane and the price in Nevada is usually about the same.0
A BTU is not a BTU. Only at the boiler or furnace input can they be compared.
A gas condensing appliance converts it's input BTUs to output BTUs more efficiently than oil or gas non condensing units. Oil is second and gas non condensing is third.
The only heat that is 100% efficient is electric you get every BTU you pay for.
But it's more expensive in most areas1 -
Likely a better way to look at it is compare efficiency.
BTU/hr of fuel input to
BTU/hr of furnace output ( to your hot water, hot air , or steam)
And the 100% efficiency of electric heating is, to my mind, one of the most pernicious fallacies around -- sorry @EBEBRATT-Ed . While it's quite true that at the point of use the efficiency is 100%, for some reason or other it is often forgotten that the electricity has to be made. Some ways of creating electricity have large environmental and social impacts -- one of the worst that way is hydroelectric dams. Some just have significant environmental impacts (photovoltaic, wind). Some are fuel burning, but the fuel conversion efficiency going from raw BTUs in the fuel to kilowatts out on the line is rarely over 40%, and may be quite a bit lower (we wouldn't tolerate that in a boiler!). Nuclear terrifies enough people who are not technically qualified that it is, politically, pretty much a non-starter.EBEBRATT-Ed said:A BTU is not a BTU. Only at the boiler or furnace input can they be compared.
There is no free lunch...Br. Jamie, osb
Ah, yes. I love to point out to my eco-minded electric-car driving friends that their cars run on coal.Jamie Hall said:And the 100% efficiency of electric heating is, to my mind, one of the most pernicious fallacies around...
I've yet to have one get rid of it. Some are downright belligerent about it! There's invariably a lot of hand-waving, often in the literal way but always figuratively, in the explanation of exactly why it's better.
Document your statement on emissions, please, and be sure it references both modern coal fired power plants and modern automotive engines. Also kindly reference exactly which emissions you are comparing (e.g. CO2, particulates, nitrogen compounds, whatever). Otherwise, bluntly, your statement is internet clickbait.nibs said:@Jamie Hall.
A car running on gasoline emits 10 times more pollutants per mile than an e car running of coal fired electricity.
Also most of the coal fired emissions are generated away from Urban areas again decreasing pollution in the cities.
Thank you.Br. Jamie, osb
@Jamie Hall.
https://electrek.co/2017/11/01/electric-cars-dirty-electricicty-coal-emission-cleaner-study/
https://cleantechnica.com/2018/02/19/electric-car-well-to-wheel-emissions-myth/ https://www.scientificamerican.com/article/earth-talk-the-coal-truth/
There are lots more studies and reports than this.
Don't usually reply to insulting posts, but I really like this site, so made an exception.
@Jamie Hall
I am just talking "point of use" I know electric heat is 100%....when it gets to your house. Before it gets to your house it's produced by coal, gas, oil, hydro, nuke etc that has it's own issues
To my crude way of thinking it's what the consumer pays for the "fuel" plus the efficiency the purchase btus are used at that results in net useable btus/$$.
Boiler manufacturers talk about "fuel to steam efficiency" same thing.
Actually, now more likely that it runs on natural gas. 😁ratio said:I've yet to have one get rid of it. Some are downright belligerent about it! There's invariably a lot of hand-waving, often in the literal way but always figuratively, in the explanation of exactly why it's better.
https://www.eia.gov/tools/faqs/faq.php?id=427&t=30 -
nibs said:
@Jamie Hall.
And what is your source for that incorrect claim?
https://www.scientificamerican.com/article/electric-cars-are-not-necessarily-clean/0 -
How many plants are generating using natural gas?
Better yet how many are nukes.....0
"coal generated electric car pollution"
This simple google search, will return many many discussions and scientific papers on the subject. The science is long settled.0 -
I entirely agree. Since, however, you seem to be intent on keeping this going, may I note that all three of your references for that incomplete statement are to "studies' performed by the electric car industry, or authors associated with it, may I suggest -- mildly -- that perhaps they are not entirely reliable? I have read those articles, as it happens, and while it is quite correct to say that for certain contaminants under certain conditions the initial statement is partly true, the overall short statement is, frankly, not, if one wished to view climate warming emissions as a whole.nibs said:@Jamie Hall
Strongly held uninformed opinions are the bane of our society,
The fundamental problem with climate change -- which I have been studying and modelling for almost 40 years now -- lies in recognizing that a) it is real; b) it is a significant threat; c) the mechanisms and causes are well understood, d) that there are available technological solutions to it and e) -- most important -- it has now become so politicized that it is almost impossible to have a rational discussion on the subject which might lead to actually doing something positive.
Indeed, I might go so far as to say that most of the reputable scientists and organisatis working on the problem have been obliged to take an extremely low profile, just to keep their jobs. This is unfortunate.
Sincerely,
James. Hall, PhD, Senior Research Scientist, [several organisations which I will not list to protect them -- and me]Br. Jamie, osb
Jamie Hall said:
I had no intention of insulting you, or anyone else. No one should ever feel insulted about being asked to document and properly reference their claims.
Yes, claims that gasoline cars emit “10 times more pollutants per mile” than electric cars are very uninformed and not substantiated by any study I have read. While electric cars can be better in many circumstances, 10 times better is simply incorrect unless you can charge the car entirely by solar, wind or hydro.nibs said:@Jamie Hall
"Otherwise, bluntly, your statement is internet clickbait."
All you needed to do was google it.
Strongly held uninformed opinions are the bane of our society,0 -
a) I agree climate change is real, but I disagree that it is anthropogenic.Jamie Hall said:
... The fundamental problem with climate change -- which I have been studying and modelling for almost 40 years now -- lies in recognizing that a) it is real; b) it is a significant threat; c) the mechanisms and causes are well understood, d) that there are available technological solutions to it and e) -- most important -- it has now become so politicized that it is almost impossible to have a rational discussion on the subject which might lead to actually doing something positive.
Sincerely,
b) I disagree that it is a significant threat.
c) I strongly disagree that the mechanisms and causes are well understood.
d) There are no technological solutions since the “problem” doesn’t exist.
e) I agree that the topic has become so politicized that rational discussion is impossible.
Most won’t invest the hour or so required, but this is one of the better presetnations I have seen by someone who has a few chops in the engineering field, at least the aerospace field. If you truly look at the long-term data and put political biases on the shelf, the science is simply neither clear nor “settled” in regards to our global climate.https://youtu.be/jPP7P43wulg
George Carlin said it pretty well...Starting @ the 2:30 mark...
https://www.youtube.com/watch?v=EjmtSkl53h4
3 -
@STEVEusaPA pretty much.
There got to be some fact to this cause where we work are boilers run on NG but when we run on oil our Jack shaft does not need to be opened as far to maintain temp. I just don't like oil because it burns very......very dirty. And this comes from the guy that has to clean the box!0
Wow, denial is a river in Northeastern Africa and George Carlin is a comedian, with no environmental or scientific training or experience. His motives were for laughs and shock value.
I have no interest in taking sides here but.....0 -
All I can say about this is that Bob Vila is and always has been a bad source of technical information. He is just a TV celebrity. The Kardashians know about as much as Bob.Voyager said:
I watched as much as I could stand of Mr Rutan's video. He may have been a great engineer at some point in his life. It might be time to get him in for a CAT scan. He is grasping at straws.
Albert Einstein1 -
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 980 Plumbing
- 388 Solar
