The head of a 4 in 1 screwdriver fell in my boiler will it affect it
acl10
Member Posts: 349
The head of a 4 in 1 screwdriver fell in my boiler will it affect it. While I was fixing a pie near the boiler I stuk a cloth in with the screwdriver to clean the inside of the pipe. When I removed the cloth the head was missing and it fell into my steamboiler. Will it affect the boiler if it sits on the bottom. I dont know of anyway to get it out
1
Tiresome. But no, it won't affect the boiler. It will just sit there.Br. Jamie, osb
What happened to the pie? I'd be mostly concerned about that. ;-)acl10 said:While I was fixing a pie near the boiler I stuk a cloth in with the screwdriver to clean the inside of the pipe.
Retired and loving it.9 -
I meant to write Pipe0
So far the boiler is working normally with it inside0
Yes, I do too, I bought a bunch of them!To learn more about this professional, click here to visit their ad in Find A Contractor.0
At least you admitted you dropped something in the boiler..0
Better the metal head than the plastic handle.0
It’s kinda like when you swallowed a penny as a kid, I see nothing I know nothing.
Maybe, just maybe someday you will get it back. This fall I changed out a furnace, where 15 years ago my employee dropped a 1" step drill bit in it. I was wondering why he would always use mine instead of his that I had just bought him. Well I found out, lol. When I was replacing the furnace this fall, the home owner came down stairs and stated, " I wonder if that young mans drill bit is still in that furnace?" Yes it was, it fell in when he was installing the outdoor wood furnace coil! He didn't want to bother getting a magnet and retrieving it. Grrrrr....
Maybe, just maybe you will get it back
There's a channellock pliers somewhere inside my kitchen wall, where years ago a drain cleaning guy dropped it while trying to remove the plug at the bottom of the upstairs bathtub J-trap. (Long story short, very old lead trap custom-bent for the application, the plug has a round profile and two protrusions that were apparently supposed to be engaged by a key with two slots in it). He went fishing with a magnet but never found it.
He comes back every couple years to root out the sewer, and one or the other of us will always mention that channellock...0 -
