How to solder 101
I think I have finger prints but my eye vision is getting poor; can't see if I do or not!0
He clearly used too much otherwise he wouldn't need to wipe the excess off with his bare fingers.Jamie Hall said:Can't you use a shorter piece of solder?
Alright Gary, let's see you do the same thing with some silfos 15 now.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
Hmmm, Do you walk on hot coals in your spare time?
Hot flux burns me... how it it that it doesn't burn you? Ceramic finger tips??
Yours, Larry0 -
I honestly have no idea, but I wonder if his fingers were wet. Water, or cool gel?Larry Weingarten said:Hmmm, Do you walk on hot coals in your spare time?
Yours, Larry
The reason I suspect this is the steam we see when he wipes it.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I think my thumb is burned from watching that video.1
Do you have a video of you soldering a horizontal fitting? Just not sure what finger(s) to use
I was thinking the bottom of the valve in the video.STEVEusaPA said:Do you have a video of you soldering a horizontal fitting?
no, can't! ---the old timers told me the diameter of the tube equals the length of solder, and i concur. That little stubby was about an inch (I didn't measure it), and it was the 'end' of the roll of solder. Had to use it up, and i have my trust right hand man film it so others would believe it!Jamie Hall said:Can't you use a shorter piece of solder?
Larry, after a hundred or two thousand solder joints (I'm a plumber from the 80s), it's just not a big deal. I get dripped on once in a while when i'm near one of the other dudes soldering. I'm not that dull- I can feel it and it doesn't feel good. But I've become used to it.Larry Weingarten said:Hmmm, Do you walk on hot coals in your spare time?
Yours, Larry
A month or two ago a blob landed on my arm/wrist. I called attention to it as it burned into my skin--showing my employee he just roasted me. Just stings for a little bit hahaha
Kinda like the old timer electrician that subs for our regular electrician----to see if a wire is hot he puts one finger tip on the ground (metal box or neutral wire), and then he taps the black wire with his other finger. Now for me that's nuts.
2 -
I would expect there to be a doubter or two, there is nothing on my finger tips, just dry normal fingersChrisJ said:
Yours, Larry
The reason I suspect this is the steam we see when he wipes it.0 -
well a horz is actually easier- at the end i gently drop the nubber of solder right on top and it's a little less of a challenge.STEVEusaPA said:Do you have a video of you soldering a horizontal fitting? Just not sure what finger(s) to use
like most small business owners i can be a real miser!EBEBRATT-Ed said:I know Silvabrite 100 is expensive but jeez!!
@GW said "Kinda like the old timer electrician that subs for our regular electrician----to see if a wire is hot he puts one finger tip on the ground (metal box or neutral wire), and then he taps the black wire with his other finger. Now for me that's nuts."
The electrician I got my license with used to do that. Drove me nuts!
I never had the guts to try that! He used to lick his finger and thumb lowers the resistance I guess
You kinda get used to the feeling after a while.EBEBRATT-Ed said:@GW said "Kinda like the old timer electrician that subs for our regular electrician----to see if a wire is hot he puts one finger tip on the ground (metal box or neutral wire), and then he taps the black wire with his other finger. Now for me that's nuts."
I never had the guts to try that! He used to lick his finger and thumb lowers the resistance I guessSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
As for the electrician.....he did that with one hand....did you see where his other hand was.
I might have done that before the non-contact testers were available.
However only on dry floors with the other hand in your pocket.
Also you don't touch with an open hand as your hand muscles will contract around the item. (This I know without a doubt) I use the back side of fingers so if something gives a buzz your hand will close away from the danger of involuntarily grabbing onto something electrically hot.
Also the back side of fingers would not be calloused like my fingertips used to be. Sometimes you can not feel 120vac thru a calloused fingertip.
This is not recommended for anyone to do...don't try this at home.
Consider this to be just another Urban Legend Story you read on the internet.2 -
You should be happy that you weren't wiping lead closet bends with your fingers in the 50's. I think most guys were using asbestos cloths.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Yes I'm just a 50 year old I missed that era. I've yanked a bunch of lead in my day though. Lead and oakum no prob0
That's funny I had a guy once build a pyramid with solder. I was so bugged out I saved the pyramid, I may still have it actually. I cut out the 2" copper fitting and it was hilarious. Put it back together myself
If the fitting isn't drinking the solder then stop, you have a problem and more solder isn't the answer3 -
Yours, Larry
Two doubters! How many guys have worked with solder so often that: when you hear sizzling you immediately let go of whatever it is you just grabbed? I suspect an extreme few. The sound of sizzling skin travels the brain faster that the nerves can transmit
Whatever you see isn't water1 -
To me, the sound of sizzling means my flux is about to be washed off. I hate that sound.GW said:Two doubters! How many guys have worked with solder so often that: when you hear sizzling you immediately let go of whatever it is you just grabbed? I suspect an extreme few. The sound of sizzling skin travels the brain faster that the nerves can transmit
Sizzling skin? Yuck.
This is some of my work.
Very nice Chris, never had the pleasure of soldering boards-1
It's more like soldering pipe than you'd expect. The same rules apply, just a different way of applying the heat and you use different fluxes. I used rosin core solder, so the flux is in the solder it self.GW said:Very nice Chris, never had the pleasure of soldering boards
The main difficulty would be getting used to holding tiny parts with tweezers and keeping the tip of the iron steady. Aside from that I bet you could learn it very fast, probably without any help.
@GW said " If the fitting isn't drinking the solder then stop, you have a problem and more solder isn't the answer"
In my younger days I thought more solder =less leaks. I have since learned the error of my ways. I used to be so picky, reheating, re soldering etc.
Now it's all pro press & pex
But when I do solder, the faster I go and the less I mess with it the better.
Clean it good, Silvabrite 100 & Nokorode self tinning flux is my recipie.
I usually grab all the fittings, chuck a fitting brush in the cordless (after cutting off the handle) and clean them all first. Hate stopping to clean fittings
Ed yes many people still solder that way.
Ok now I'm really gonna freak some people out, the fittings are "factory cleaned".. I don't brush the fittings unless they have been hanging around for months. The flux can easily burn off a little aging.0 -
I do the same. Pipe I pretty much always clean though. For flux I've been using my finger with a rubber glove. I've been trying to figure out how to get less flux than a brush. Have you ever tried Ruby Fluid?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
My pappy, bless his resting soul, use to stand in front of a furnace pot full of molten lead, and when the apprentice wasn't watching, would stick his clean index finger in his mouth to coat it with spit, then when the apprentice was looking, would quickly dip his finger into the molten lead, and exclaim, "OK, it's ready to pour..." So, if you see older plumbers with second and third degree burn scars on their index fingers, you know who they came up under2
@GW Yes others have told me that if the fittings are "new" that they don't have to be cleaned. Guess I am paranoid so I still clean everything.
In fact if I have an old dirty used fitting that I have to connect to sometimes I clean it as good as possible and then heat it put solder on it and then wipe it before I assemble it and solder it just to make sure it will "take"0 -
Ed wow I guess if you have the time that's cool. I've heard of that, my old timers called that "tinning' the fitting. In that context we were discussing larger copper fittings like 3 or 4". I have only soldered up a 3 inch in DWV and didn't bother with the tinning protocol.
I was on a boiler install today and was soldering. We use a mix of PP and sweat. I grabbed a copper sweat fitting and looked at it, looked at it again, looked at it a third time, I grabbed my fitting brush, it was a little too old looking. But I almost went cold turkey on it .
My 17-year-old son is brand new, green as they come. He's a smart kid, college bound. He's been helping us this summer. The other day he totally nuked a half-inch fitting he was soldering . He said he didn't know about "too much heat", that he was more familiar with soldering three-quarter inch. I had him solder a new piece with a new fitting, this time with my supervision. When I saw the flux starting to burn away I mildly barked at him. "Move the heat!" i snapped.
I think half of soldering is heat management. The other half is general experience.0 -
@GW , Yeah I only "tin" if it's a beat up fitting that is questionable.
Glad to see your son working out.
"Heat management" and experience is what it's all about as you CORRECTLY said.
Decisions. what size tip? how much heat? depends on where your at. Inside an ac unit or close to wood you have to adjust your experience versus out in the open or on a vise.
Just experience and no two people do it the same0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
