No more Steamaster Tablets?
http://www.supplyhouse.com/Rectorseal-68732-Steamaster-Tablet
I know I cant find them either.... anyone else know where they sell them? would help alotASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
I am thinking it's been replaced by Rectorseal 68742 5.3-Ounce Surgemaster Steam Boiler Treatment. I've ordered some, but have yet to use so no comparison yet.New England SteamWorks
newenglandsteamworks.com0 -
I'm pretty sure Surgemaster is totally different than Steamaster.
Best I can tell, only Supplyhouse stopped carrying them, Rectorseal still makes them.
I'm probably going to switch to Rhomar when I run out of Steamaster, only because it seems easier to get with better customer service. Rhomar seems fantastic in that regard while Rectorseal won't even respond to emails.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Surgemaster is a cleaning product not really a water conditioner. It seemed to do a great job for my system after install , the water level really settled in after I used it. I hope Steamaster is still available somewhere.
hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
They stopped years ago which is why we pushed for Supplyhouse to get them, which they did. Now they dropped them.Fred said:Doesn't appear to be available through Amazon anymore either.
I think I bought mine from Amazon back in 2012, and soon after they dropped it.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Sid Harvey can order them in...New England SteamWorks
I used to have a Sid Harvey close to me. They moved out of my area years ago. Where are they now?0
I just bought 2 bottles at RE Michel . They were in stock at their main warehouse for my area.hvacfreak
Rectorseal 8-Way treatment seems to be the same stuff, turns my water purple... Claims the same benefits as the tablets - in a convenient liquid form!0
I just got off the phone with Supply house and they said you may still be able to source the product, somewhere, perhaps locally. Apparently due to the chemical makeup UPS wasn't happy shipping the SM tablets.Richard Ban
Detroit, Michigan (Dunham 2-pipe vacuum)0 -
That's Sodium Nitrite. Sodium Nitrate is a strong oxidizer. I don't think you'd want it in a system.Ban said:Rectorseal 8-way is not the same. I just checked out the data sheet and its ingredients are different. Also, the important ingredient in Steamaster Tablets are Sodium Nitrate, This is only at 6 % in the 8-way vs 44% in the SM.
I was able to find them as mentioned above at Sid Harvey, I found a brach in Michigan and they will be shipping it to me, ironically though UPS. They did want a comercial address.Richard Ban
They have them at Sid Harvey's. I just bought one from them here in NJ.0
I found a couple of places in NYC....that stock themASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Maybe the heating help store should sell it..gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.8 -
Thanks Peter!
3PSI gauge0 -
Is 8-WAY a good alternative? Better? Or worse?0
Thanks Pete, I'm going to order as my batch from Supply house is now used up. I am sold on this product. I used no treatment in boiler installed in 2012 for first year then started using Steamaster tablets. I flush out the boiler with a wand at the beginning of each season. The amount of muck that flushes out has reduced each year. this year, it amounted only to a very small amount of murkey brown water, like watery chocolate milk. Most everything was clear I think I could have skipped a year, but I'm not going to get in that habit.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
They are on amazon for sale, I just got some. Only 7 left.
Thanks Peter0 -
I just ordered a bottle, so now 6 left in stock.0
I just ordered a bottle to refresh my stock...0
Once the original 2 cases are gone thats the end of them until I get a new shipment in so grab them while they are there. I will be raising the price a few bucks, I ended up losing money on the last 2 cases, don't tell my boss lol.Peter Owens
SteamIQ0 -
I just ordered the last one on Amazon.Steve Minnich0
Just ordered 1 and 6 left!0
Last week I found a bottom on my shelf that was hiding. I didn't think I had used 2 bottles since they appeared on Pex Supply. But, for good measure, I ordered another bottle just now. Thanks for putting them on Amazon!Dave in Quad Cities, America
In case anyone is still looking for Steamaster tablets, I noticed that Rectorseal has a product called "Scale Flush." The ingredients and percents by weight listed in section 3 of the MSDS are identical to those in Steamaster tablets. I haven't located a retailer that carries them yet (tried Supply House and Amazon), but I'll keep looking.Just another DIYer | King of Prussia, PA
Hap_Hazzard said:In case anyone is still looking for Steamaster tablets, I noticed that Rectorseal has a product called "Scale Flush." The ingredients and percents by weight listed in section 3 of the MSDS are identical to those in Steamaster tablets. I haven't located a retailer that carries them yet (tried Supply House and Amazon), but I'll keep looking.
https://wwcsupply.com/rectorseal-68732.html
Just refreshing the thread as 2 bottles of Steamaster are showing still available... just follow the first post and use the Amazon link in this HH.. post. GL https://forum.heatinghelp.com/discussion/187735/steamaster-sighted-time-of-post
One way to get familiar something you know nothing about is to ask a really smart person a really stupid question0 -
The two bottles mentioned by reggi are now heading my way. Amazon now shows zero available.
Thanks for the heads up.Dave in Quad Cities, America
http://grandviewdavenport.com1 -
Dave! How could you!Dave in QCA said:The two bottles mentioned by reggi are now heading my way. Amazon now shows zero available.
Thanks for the heads up.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
@Dave in QCA Good grab!!
Went to update and it looks like they came up with 1 more
So 1 available at the time of this post
Link is at HH post
How can I mute this thread lol
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 110 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
