Worlds smallest header?
cell # 413-841-6726
You see a header there do ya?
I find calculating the steam velocity can be entertaining at times http://www.tlv.com/global/TI/calculator/steam-velocity-through-piping.html
After derating for altitude, the 211A I posted a few weeks back would hit 145 FPS through 2" Sch.40 at 0.5 PSI.0 -
What I don't understand about steam velocity ratings is they never seem to agree with how long it takes steam to hit my main vents?SWEI said:I find calculating the steam velocity can be entertaining at times http://www.tlv.com/global/TI/calculator/steam-velocity-through-piping.html
The fastest time on my long 2" 29' main is about 60 seconds. Shouldn't it be more like 2 seconds?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The steam is collapsing as it approaches your vents Chris. If the pipe was already at 212 degrees at the scene entered it it would vent faster. The same velocity charts are based off of a system that is already up to temperature at the speed that travels to the Steam that is being usedCost is what you spend , value is what you get.
cell # 413-841-6726
How much could the main have cooled off in 5 minutes with 1" insulation?Charlie from wmass said:The steam is collapsing as it approaches your vents Chris. If the pipe was already at 212 degrees at the scene entered it it would vent faster. The same velocity charts are based off of a system that is already up to temperature at the speed that travels to the Steam that is being used
It would have to be below 140 degrees or your vents will not open to allow air in.Cost is what you spend , value is what you get.
cell # 413-841-6726
Not true.Charlie from wmass said:It would have to be below 140 degrees or your vents will not open to allow air in.
My vents are located in a cold crawlspace and they are not insulated, nor is the 3/4" nipple connected to them. This nipple drops below 180F in about 4 minutes.
The insulated steam pipe is without a doubt still above 180F in 5 minutes.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I suggest you insulate the nipple. Or even better relocate the vent to a warmer area so it takes longer to cool.Cost is what you spend , value is what you get.
cell # 413-841-6726
What benefit would this give other than making the system struggle trying to push air out?Charlie from wmass said:I suggest you insulate the nipple. Or even better relocate the vent to a warmer area so it takes longer to cool.
All of the radiator vents will still be wide open.
In fact, I'm betting this would cause all sorts of balancing problems. Half the main full of air, half not, main vents still shut etc.
I rely on that nipple to cool to reset the Ecosteam, especially when it's below zero out and I'm running 3 CPH. I have around 5 to 6 minutes in between cycles.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
If the vent is warm and close what air would be stuck?Cost is what you spend , value is what you get.
cell # 413-841-6726
The 10 wide open radiator vents will let air in.Charlie from wmass said:If the vent is warm and close what air would be stuck?
That installer was a "good hot-water man"ChrisJ said:You see a header there do ya?
. And yes, you have me beat- smallest one I've seen was 1-1/2".
Consulting0 -
That problem of the apparent velocity of steam in a main being much less that the calculated velocity is kind of subtle. However, until the boundary layer of steam against the pipe reaches 212 (at "normal" atmospheric -- but close enough) steam simply will not go significantly farther -- it will, quite happily condense. If the pipe is nice and warm -- your 180, @ChrisJ , for instance, that will happen fairly quickly -- but not instantly. So the bottom line is that the steam front in the pipe will move only as fast as the steam will heat the pipe.
Oddly, the back pressure from a vent won't affect this all that much -- assuming the vents are at least reasonable. Which debate I have no intention of reopening...
Saturated steam is funny stuff.Br. Jamie, osb
Has anyone probed a steam system and measured 212°?0
I figure that at 0 psig it's cooler than 212° unless there's no air in system. Because the partial pressure of the water vapor is less than 0 psig.ChrisJ said:
New boiler new HeaderCost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating4 -
Looking good!0
Thanks. Definitely better than what they had.Cost is what you spend , value is what you get.
cell # 413-841-6726
Great job!! @Charlie from wmassASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Charlie saves another one. Nice job!New England SteamWorks
newenglandsteamworks.com0 -
That's some really thick insulation for those small pipes. lol.
Looking good Charlie.0 -
0 PSIG is typically 14.7 PSIA, which means a boiling point of 212F at sealevel. Above sealevel, this temperature should gradually drop as you get higher and higher.jumper said:
At 2000 feet it's 13.7 PSIA so a boiling point around 210F.
At 5000 feet it's 12.2 PSIA so a boiling point of about 202F.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Boil water in an open pot. Stick a thermometer into the steam –not the water– and see if you get 212°.0
If you can see it, it's by definition not steam. It's already condensed. Use a teapot, & put the thermometer in the "empty" area between the spout & the cloud. That outta be a lot closer to 212, depending on altitude/barometric pressure.0
Spout increases velocity to sweep away air. My point is that when there's air in a steam heating system the gases are less than 212° at 0 psig because part of the pressure is contributed by the air. So the water vapor pressure is less than 0 psig. Or am I missing something?0
Steam displaces air. They do not blend due to difference in densities.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
