Why are energy efficiency standards so far behind the technology?
    Steamhead Member Posts: 16,883
    To a troll, that IS an ivory tower!
    Consulting
  • ChrisJ
    ChrisJ Member Posts: 15,766
    In the words of Pope Julius II, When will you make an end!!!!!!!!!
    Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
  • njtommy
    njtommy Member Posts: 1,105
    The Navien is an inexpensive boiler. Look up HTP or Lochinvar you will find that their prices will be double or even high depending on model.
  • njtommy
    Trying to take it up to 500 comments. Lol
  • ChrisJ
    Clearly, we ain't done yet........... :s
    The proper response would've been "When I am FINISHED!!!"
  • vaporvac
    vaporvac Member Posts: 1,520
    AJinCT said:
    Steamhead, Quick Google search for a 75,000 BTU gas boiler gives me a Peerless for $1770, a Navien NHB-80 is $1825. Even if you figure the time savings of not hauling the CI clunker around is eaten up by venting and re-piping for the Navien, the Navien is still a much better deal.
    "A lot" is not a defined number. It's pretty obvious that a lot of steam systems are a mess, and steam is way less forgiving than hot water.
    I was considering the space consumed by a big steam boiler and the maze of pipes versus a mod/con with PEX piping, the controllability and zoneability of the mod/con, and the maintenance needed for the steam system versus virtually none for gas hot water.
    From extensive reading on this site, I would argue that steam is MUCH more forgiving of bad installs: it may bang (usually due to pipe sag), hiss or be slow to heat, but even with a gaping hole in the boiler, it will still heat! Most of the bad HW installs result in no or sub-par heat. It also doesn't take much to get a steam system running top-notch once one knows what to do.
    I'd also say that steam systems don't generally need a lot of maintenance. Everything needs something done regularly if you want it to last. It's becoming more apparent that HW installs require water maintenance, as well.
  • BobC
    BobC Member Posts: 5,479
    And how many Naviens will you have to buy to last as long as the Peerless?
    Also we don't usually discuss pricing per se.
    Bob
    3PSI gauge
  • ChrisJ
    Bob
    I believe @Steamhead asked him to provide pricing.
    I think he made an exception for this rare..............treat.
    Probably several.............
    We're not supposed to discuss pricing at all. That appears at the top of each page, with a yellow background. Pretty easy to see, if you're paying attention.
    Consulting
    That was sort of a trick question. Posting numbers is something AJinCT consistently refuses to do. I didn't specifically mention pricing. Here is my quote:
    Steamhead said:
    Post your numbers. If you have them, that is. I suspect you don't.
    as in, which boilers were cheaper than the Navien?
    But, as @njtommy correctly pointed out:
    njtommy said:
    The Navien is an inexpensive boiler. Look up HTP or Lochinvar you will find that their prices will be double or even high(er) depending on model.
    which opens up a lot more CI boilers as being less expensive than a mod-con. To say nothing of all the extra installation work needed, assuming there is a proper and safe way to install one, as @The Steam Whisperer correctly pointed out.
    Consulting
    ChrisJ
  • R Mannino
    R Mannino Member Posts: 440
    Well said Frank, I'm still waiting for some numbers too...........
    Don't hold your breath..............
    Consulting
  • ChrisJ
  • Abracadabra
    Abracadabra Member Posts: 1,948
    AJinCT said:
    Gas hot water can run for 20 years with zero maintenance.
    LOL!!!
    CanuckerChrisJvaporvacGordy
  • njtommy
    edited March 2016
    @AJinCT I'm very familiar with the Navien products do to having one in my own home along with having installed quite a few of them as well.
    I really like my Navien combi, but it lacks control options the tdr is crap.
    AJinCT
  • ChrisJ
    edited March 2016
    LOL!!!
    Yeah......
    He kinda bought the farm with that comment.
    ChrisJ said:
    LOL!!!
    Yeah......
    Well, well.
    Here is the boiler manual for the Weil-McLain Ultra, a mod-con that has sold a few units. The maintenance section begins on page 109:
    http://www.weil-mclain.com/sites/default/files/field-file/ultra-manual_1.pdf
    Triangle Tube's Prestige Solo's manual is here- this is also fairly popular as mod-cons go. Jump to page 64 in the PDF for the maintenance instructions:
    http://www.triangletube.com/documents/33/Prestige_60_175_250_399_Manual.pdf
    On the cast-iron side, the maintenance instructions for the Burnham Series 2 start on page 32 of this PDF:
    https://file.ac/ppQZpobSbGs/Series 2 I&O.pdf
    Give 'em enough rope....................... >:)
    Consulting
  • Gordy
    Gordy Member Posts: 9,546
    Im going to go out on a limb here. I'm assuming that AJ is talking about a dedicated water heater in a radiant heat application. Since he mentioned cryo-tek.
    With that being said it is entirely possible for a water heater to last for 20 years. Being it would not be subject to the constant freshwater.
  • ChrisJ
    With zero maintenance?
    Yeah, boilers seem to love that.
  • Gordy
    Depends on the type of water heater, and water quality when filled Chris. AJ claims a need to drain, and refill. That would be worse than filling, and let it go.
    What tears a water heater up Chris?
  • Gordy
    My CI boiler is 22 years old. It's not needed one part. Do I check things, yes.
  • R Mannino
    Reliability in a heating system is overrated (tongue in cheek). It's CI so it's a clunker (again tongue in cheek).
  • Gordy
    edited March 2016
    The original lasted 41 years.....thing is the original and existing are connected to radiant. Present is bypass piping original was not.
    AJinCT said:
    I was referring to a gas hot water system with a boiler and a closed loop. Cryo-Tek has to be changed every 10 years. I grew up in a house with gas hot water, and it ran for 20 years without anyone touching it.
    Sure about that? For example, are you sure the service person didn't come while you were in school? No one ever drained the expansion tank? Bled the radiators?
    Unless you were there 24/7/365/20, your statement really has no basis.
    Consulting
  • Gordy
    Like I said I went out on a limb. Timberrrr.
    Why was the system filled with glycol?
    No you don't need to drain, and refill system periodically. Ever. Unless it has to be done to do work on it.
    Looks like AJ needs a backhoe, he's digging himself deeper and deeper....................
    Consulting
  • ChrisJ
    It's ok.
    He's using a steam shovel.
  • Gordy
    He's had the backhoe for quite awhile. What he needs is for a contractor to fence off the construction site because, apparently, that 20 foot chasm is simply irresistible to many.
    It takes talent to be thebackhoe operator, and be able to bury yourself with it.
  • Fred
    Fred Member Posts: 8,542
    Must be more fun to continue to beat a dead horse than to drag it to a hole and bury it. The stench is the same in either case, at least while the deed is being done. Why does everyone continue to "take the bait" (of course unless you are having fun) ?
  • KC_Jones
    KC_Jones Member Posts: 5,741
    Bingo....it's about the entertainment value for me at this point.
    2014 Weil Mclain EG-40
  • R Mannino
    Ah ha!
  • Fred
    Twisted sense of humor, LOL!
  • SWEI
    SWEI Member Posts: 7,356
    Rich said:
    Codes such as IECC 2012 - 2015 would have to be adopted by States and once again their builders ****'s would cry bloody murder.
    Tell me about it. We spent two years on a collaborative multi-stakeholder process adapting and modifying the 2009 IECC to meet the needs of New Mexico's different climates, based on a system of zones, and aligning it with our state's deep experience in alternative building techniques, passive solar, and tough economic times. The then-new Governor's handlers decided she should kill it. So she did.
    Rich_49
  • Gordy
    Section C402 is where it all starts. 11 pages of static on the radio this is. If code adoption can not be implemented none of this matters. The reasons why see Rich, and SWEIs posts.
