any experimenters here?
jumper
jumper Posts: 2,628
For example using packing in place of ferrule?
  • HomerJSmith
    HomerJSmith Posts: 2,837
    edited October 7
    "…packing in place of ferrule?"??? I don't think so.
    I'm a big time experimenter, it seems. Everything that I've done that's failed on reflection was an experiment,
    epmillerAlan (California Radiant) ForbesSteamNow
  • Hi, The ferrule idea sounds like risky business. You could do a test and see at what pressure the packing connection blows off the pipe 🚀. My question is what problem are you looking to solve?
    Yours, Larry
    hot_rod Posts: 28,776
    a compression ferrule is a connection system. It locks into the pipe or tube to keep it from pulling apart.
    Although there are other definitions for a ferrule I use wire ferrules on stranded wire to give you a single pin for terminal strips
    HVACNUT Posts: 7,811
    Why? Why not cut it back and install a new ferrule? Not long enough? Get some tubing, a compression union, and a new ferrule.
  • jumper
    jumper Posts: 2,628
    Question is about joining pipes & tubes on bench and testing connections against water hammer and flexing.
    Decades ago a colleague used to do that. Both solder and compression connections can fail. Some flares do too. So experiments were about what is easiest to fix.
    It is a common connection in Europe. Radiator, thermostatic, balance, prv valves, piping and inside a lot of mod cons is done with ferrule fittings.
    Pex to manifolds are usually a ferrule fitting. IOt is a grst fitting for PAP tube.
    Jamie Hall Posts: 28,004
    Ferrules (compression rings) work. Single flares work. Double flares work. Captive o-rings work. Soldering works. Brazing works. Welding works. Packed fittings work.
    They also all can fail…
    It's not what works, it's what are you trying to do? What pressures? What cycles? Peaks? Temperatures? Ease of disassembly for service? Use the best tool for the given job.
    HomerJSmith
    EBEBRATT-Ed Posts: 21,365
    Across the pond they call them "Olives". They even make puller to pull the olives off but I would do what @HVACNUT suggested.
  • jumper
    jumper Posts: 2,628
  • jumper
    jumper Posts: 2,628
    »They also all can fail…« what about threaded connections? Dishwashers or ice makers?
  • ChrisJ
    ChrisJ Posts: 17,777
    At that, IMHO whoever came up with those little piercing valves used for icemakers and the like should be… don't know what. Something evil, anyway.
    PC7060
    pecmsg Posts: 7,654
  • PC7060
    PC7060 Posts: 1,982
    pecmsg
  • ChrisJ
    I guess technically a pack joint is a compression fitting that uses packing. It also uses a clamp to clamp the fitting to the pipe.
    They work extremely well and do not seem to care about imperfections in the pipe. But I certainly wouldn't try to use packing in place of a ferrule on a fitting designed for one. There's really nothing to hold the pipe in the connection so it doesn't push out.
  • jumper
    jumper Posts: 2,628
    Crank too hard on faucet bonnet and stem won't turn. So why can't packing secure tube linearly?
  • ChrisJ
    edited October 11
    I don't think your hand compares to 100+ psi pushing a tube out of a fitting.
  • Intplm.
    Intplm. Posts: 3,164
    The only Ferrell/ furelle that might do that is this guy!?
    PC7060
