Draining condensate into a septic tank/field ?
I would think not an issue, if it's properly neutralized.
How to test that it's neutralized ? Maybe a valved drain/test port after the neutralizer where you can take a sample (while the boiler is running and condensing, of course).
Im up for suggestions if someone has done this already.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,716
    Yes, but why if u can drain elsewhere?   Depends on how much discharge too.  Even neutralized condensate probably does not help Bacteriologic breakdown   mad Dog
    Jamie Hall Member Posts: 27,677
    Properly neutralized it wouldn't be a problem -- unless your local health authority cuts up rough on it.
  • nibs
    nibs Member Posts: 516
    We started our condensing boiler and a new septic field at the same time, we found that we needed to add baking soda by the cupful to neutralize the acidic condensate water. every time it smelled off, in went another cupfull. So I built a 3" diameter 30 " vertical 'tank' and filled it with marble chips, put the condensate in to the bottom and let it flow up through the chips, this settled the septic down to its current sweet smelling self. Not that my favorite wife it a retired clinical microbiologist so we had an expert onsite. Now that we have a robust septic system I feel that we could skip the chips, but since it is very low maintenance we are keeping it in place. Tank is simple 3" pvc pipe with a glued cap on the lower end and a threaded cap on the top end. two fittings for 1/2" pex one about four inches up and another about four inches down, put them in before you put the bottom cap on as you need to get your hand inside to tighten the inlet & exhaust fittings.Keep the chips below the outlet fitting so that you can make sure it is flowing.
    Mad Dog_2Dave Carpentier
  • pedmec
    pedmec Member Posts: 1,478
    Pump the condensate into a working washing machine standpipe. laundry detergent will neutralize the acid. Fact.
    Mad Dog_2Intplm.
  • psb75
    psb75 Member Posts: 1,158
    I've asked "experts" about the discharge from water softeners and the effects on biological activity in septic systems. I got "crickets."
    Mad Dog_2
    hot_rod Member Posts: 28,062
    seem like you could just pump it on the ground or into a soak away pit. It ends up in the ground after it goes through the septic tank anyways
    A basic ph test strip would indicate ph before and after any neutralizers
    Mad Dog_2
  • GroundUp
    GroundUp Member Posts: 2,544
    edited March 2024
    Unpopular opinion: the septic for an occupied home will never even notice condensate whether it's neutralized or not. Those <4 gallons of condensate made daily will be neutralized in the tank by a single toilet flush. If you have iron piping or are using an iron pump to get it into the septic, then there may be some trouble. The same can be said for an unoccupied space. I've been in thousands of residential mechanical rooms around my parts, and have never once seen a neutralizer that I didn't install- which only happens in the above exceptions to my rule. With that said, I've also never seen any negative effects on the septic of an occupied home caused by flue condensate. Is it "right"? Probably not. Does it work perfectly 99% of the time? Absolutely.
    pecmsgethicalpaulrick in Alaska
    Agreed, @GroundUp . Septic systems are astonishingly poorly understood, and very little usable research on them. But like most living organisms -- which is what they really are -- they can adjust to an astonishing variety of "food" as long as you don't overload them or change their "diet" too fast.
    GroundUp
  • yellowdog
    yellowdog Member Posts: 294
    I use a neutralizer to protect the pump more than anything. I now use the PurePro combination pump with neutralizer built in.
  • Zman
    Zman Member Posts: 7,614
    I think it depends on a few things. With a properly maintained neutralizer in a house that is occupied most of the time, I have never seen an issue. In second homes, I have seen high PH damage the tank pump and the low flow from the boiler freeze up in the underground pipe. A system in an unoccupied house does not dilute the PH and is not warm enough to prevent freezing of the condensate.
    Albert Einstein
  • Dave Carpentier
    Dave Carpentier Member Posts: 640
    edited March 2024
    The only thing I found, 24 yrs ago, was a study out of University of Wisconsin (hope I recalled that correctly) where they found no adverse effect (slightly positive effect, it seemed) on a properly sized, built, and maintained septic system. Ultimately, I wont know about my personal experience until mine fails but I'd say 24 yrs later , it seems okay to do.
  • Dave Carpentier
    Thanks guys, good replies.
    Draining it directly outside is not an option in the layout.
    The drain/septic is all plastic except for the concrete 1000 gallon tank.
    The dilution into the tank water would make the concern moot, it seems.
    Still, if I have enough vertical space between the bottom of the boiler and the available drain point (with an air gap), I'll probably diy some kind of tube neutralizer. If it requires a lift pump , I'll give it a pass.
  • exqheat
    exqheat Member Posts: 229
    Is there an effect if it gets to the well?
    John Cockerill Exquisite Heat www.exqheat.com Precisions boiler control from indoor reset.
  • jumper
    jumper Member Posts: 2,603
    How does wee bit of carbonic acid harm soil? If it does bury some ashes.
    Well? What well? Domestic water? If your septic leach field is close enough to your well for that to be a concern, you have much bigger problems...
    ZmanGGross
