Why I don't like SS Flex supplies...
Top two pictures....installed 21 years ago....ALL good..
The Bottom Photo.. a SS "No Burst" (a hem!) flex supply that blew after only a few years. Let go over a long weekend while the HO's were away...Destroyed the first floor ceiling, living room wood floor, furniture...over 50 K damage and that was 15 years ago.
Not on MY jobs or my house...Piece of mind and I love the Ridgid Bender! Mad Dog1 -
What kind of pressures are we talking about? On vacation homes, I always tell the owners to shut off all the angle stops and washing machine bibbs. Had a dripping washing machine bibb over a 4 mo period. Did an amazing amount of water damage.0
@Mad Dog_2 Unfortunately you're talking the difference between a plumber/craftsman vs. the ease of DIY.
I had a customer have one burst under the toilet on the first floor. Probably ran for a day. It was a disaster.
I don't have them either. Always turn off the lever at the box for the washing machine when not in use. I also always shut off all the water to the house whenever I'm going to be gone over night or longer.
2 -
That can be true if overtightened. But, yes, I have an old Mayo jar filled my nice red brass nuts. Mad Dog0
Something happened to that flex line, but it wasn't normal city pressure.
See my sight glass boiler videos: https://bit.ly/3sZW1el5 -
Plastic flex lines like that will eventually dry out and burst if you wait long enough. In order to make the plastic that flexible and cheap it has to be made less durable.0
Tired of years of weeping brass ferrules and dezincafication of the brass nuts I switched to flex supplies and make sure water pressure is in safe ranges. Everything can break or leak, that's why we have home owner's and business liability insurance. Stripers are moving, that is a better use of time on Long Island IMHO.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating3 -
Lead ?? All that PVC glue & Primer is great for our drinking water 🚰 supply, right? Lead, atleast, is a naturally occurring metal mined from the Earth. Glue & primer are a man-made toxic poison. Brass risers? No, actually .. never seen one "fail" Chris. Mad Dog 🐕0
The 2 reasons i have had problems with weeping ferrules have been super thin copper tube and ferrules that were old and have hardened with age sitting on the shelf. If they're old you have to het them up to anneal them before you use them.0
I've seen many Red Brass risers in service over 100 years. Courthouse in the Bronx had 6" and 4" Sanitary Building house drains close to 100 years..Still no leaks. Mad Dog 🐕0
There's no PVC glue in water it evaporates long before you get it wet and even if it didn't it would after. It doesn't stay there it melts the plastic and leaves which is why the plastic doesn't stay soft.Mad Dog_2 said:Lead ?? All that PVC glue & Primer is great for our drinking water 🚰 supply, right? Lead, atleast, is a naturally occurring metal mined from the Earth. Glue & primer are a man-made toxic poison. Brass risers? No, actually .. never seen one "fail" Chris. Mad Dog 🐕
This is similar to the formaldehyde argument.....
Formaldehyde isn't toxic in small levels.
Leads is.
Uranium is a natural occurring metal as well.....Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
Water pressure doesn't spike high enough to do damage where this happened, in the suburbs.
In a Manhattan High Rise that's Possible. Brass nuts and ferrules don't weep if you dope, snug and watch them for 15 minutes. Charlie, that's great that you leave it up to the insurance policy as a last resort.. Alot of damage & loss could be prevented. Knock on wood...never had an insurance claim. That failure is a simple hernia of the rubber tubing (the weakest link) Like the abdomen wall, the SS is ruptured. This doesn't happen with a solid copper supply tube. Mad 🐕 Dog0 -
Ask @DanHolohan about all of the pinholes in his copper pipes.Mad Dog_2 said:Water pressure doesn't spike high enough to do damage where this happened, in the suburbs.
1 -
Is this pride and craftsmanship? Flexes are great for guys who can't rough the angle stop even close! Like this fella..ha ha Mad Dog0
I guess if you need to shut an overflowing toilet while bathing, this works! Mad Dog 🐕1
Exactly, there is no safe amount of lead. Just progressively worse Neurodegeneration.ChrisJ said:
Leads is.
At least with most other carcinogen's you may or may not suffer disease. Breath asbestos all your life? You might get mesothelioma, but you might also stay healthy to 100 and instead die from a piano falling on you.
All that said I really do hate how much plastic we use. I think we are going to find that the endocrine disruption we are bringing up on ourselves will be our undoing as a species if climate change doesn't do us in first.2 -
Oh I'm not arguing for one product or another.Mad Dog_2 said:Is this pride and craftsmanship? Flexes are great for guys who can't rough the angle stop even close! Like this fella..ha ha Mad Dog
I just know brass and copper aren't flawless.
1 -
vinyl chloride is dangerous. if it isn't mostly polymerized it can be dangerous.0
Look up the boiling point of vinyl chloride.mattmia2 said:vinyl chloride is dangerous. if it isn't mostly polymerized it can be dangerous.
Of course there's no PVC in pex. Pex is cross-linked polyethylene.
Nothing is flawless. I'm just talking more durable and long-lasting. Thats what I'm interested in. I don't know where they use PVC for water mains, I'd rather see Uponor Propex if ya gotta go plastic . MAD DOG0
As far as I’m aware PVC is NOT allowed on potable water!0
I don't think it is but I thought that was due to how fails under pressure.pecmsg said:As far as I’m aware PVC is NOT allowed on potable water!
@Mad Dog_2 do they make 8" and bigger expansion connections?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The few I installed in my house are almost straight.EBEBRATT-Ed said:Too many people twist the flex connectors into unreasonable positions. If used with common sense and kept an eye on they are probably ok
Who is going to keep an eye on them?EBEBRATT-Ed said:Too many people twist the flex connectors into unreasonable positions. If used with common sense and kept an eye on they are probably ok
1 -
Karl Reynolds said:Most stainless steel flex connectors have a tag on them stating to replace every ten years. How often does that happen? Probably never.
Well.
In my house I exercise all my valves every few months. If I'm down the basement doing something I'll go around and turn all of the valves on and off a few times. This is including the main shutoff on the city water.
So, in my case, things are kept maintained because I'm the lucky winner that gets to fix them.
Braided hoses I replace when I feel it's necessary.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
Just like float-type LWCOsKarl Reynolds said:Most stainless steel flex connectors have a tag on them stating to replace every ten years. How often does that happen? Probably never.
See my sight glass boiler videos: https://bit.ly/3sZW1el1 -
I enter dates in my cheque book program so that I have some idea. If your car hoses can last ten years under those gruesome under hood conditions then modern industry can produce lifetime hoses. But how do consumers or even professionals identify them?Karl Reynolds said:Most stainless steel flex connectors have a tag on them stating to replace every ten years. How often does that happen? Probably never.
1 -
Some last much longer than 10.jumper said:Most stainless steel flex connectors have a tag on them stating to replace every ten years. How often does that happen? Probably never.
I think my dad still has the original on his truck from 97.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Reckless??? Hilarious!!! Your claims are USUALLY all reckless, dude! : "You don't need no stinkin' equalizer!!!! ...I know more than The Deadmen and Engineers of yesterday !!!" You mean the brilliant thinkers of their day who actually had the remarkable intelligence and foresight to INVENT, CREATE, AND DEVELOP the plumbing and heating standards that have kept us warm, healthy and thriving for hundreds of years???
I don't know what your particular background or training is Ethical Paul, but Something tells me its not actually turning wrenches and busting your hands up and taking dozens of stitches putting boilers and sewer pipe together. (Just an educated guess) There are Black Belts who do perfect forms and break boards and put on a great show...they look cool...Then there are No holds Barred Street fighters that destroy the BB in a Match because they have actually HAD real fights and know what actually works. You do a LOT of pontificating and theorizing. Vigorous and thorough debate is swell....That's your right to do that, but Don't think you can poo poo everyone else's decades of REAL LIFE experience. Just because you MAY be the smartest man in the room, doesn't make you correct OR the most KNOWLEDGEABLE man in the room.. Mad Dog 🐕0
- 120 Geothermal
- 394 Solar
