Special thanks to Steamhead
It was a pleasure to kibbutz with him again. It had been a long time since we crossed paths in Chicago and Cleveland. Needless to say Steamhead got the new burner up and running lickedy split. And taught this old dog some new tricks.
Thanks again for the conversation, and the education, not to mention Mr. Mouat is smiling upon you from his grave for rescuing one of his systems.
I believe Mr. Mouat is buried in Lakeview Cemetery, Cleveland, if you want to check his smile!
The Garfield Monument there is a work of art as well.--NBC0 -
He is. I actually have his grave location info somewhere in my records.nicholas bonham-carter said:I believe Mr. Mouat is buried in Lakeview Cemetery, Cleveland, if you want to check his smile!
The Garfield Monument there is a work of art as well.--NBCgwgillplumbingandheating.com
I also want to thank Steamhead. Just for being Steamhead. And really, isn't that enough?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes7 -
The pleasure was mine, Gerry.gerry gill said:I had a call from a fellow in the country side in Ohio who has a Mouat system with a bad original oil burner. I'm 60 now and spent my entire trade life working in areas served with gas. Not only did i not know how to replace an oil burner, i had never seen an oil burner. ..I know, the oil guys are saying whats the big deal..lol... but i didn't want to do something stupid so i called the one person i knew, who would know, and Steamhead made a road trip for it.
And I'll bet Reginald W. Beckett is smiling too, because one of his original burners lasted as long as it did. It was making lots of soot though, not sure if this was due to improper setup or something else. We replaced it with a current-model Beckett AF.
That Beckett Commodore model CB-1 burner was interesting. It's an axial-flow design like the Midco RE series gas burners use. And I've never seen an air tube that was shaped like a fire-hose nozzle- 5" down to 4" IIRC. That must have made for some serious air velocity. There was no spinner vane inside the tube- if it came from the factory that way, they must have relied on that velocity to mix the sprayed oil with the air.
Sounds dangerousJohnNY said:I also want to thank Steamhead. Just for being Steamhead. And really, isn't that enough?
Oh, if any of you are thinking of traveling through Wheeling, WV over the next few months- don't. They have the main I-70 interchange all torn out. If you're just passing thru, use the I-470 bypass. If you're connecting with one of the other highways running thru there, do it elsewhere. It's one detour after another and they're not always marked properly. I came back via Steubenville, OH and Weirton, WV on US 22.Co-Founder, All Steamed Up, Inc.
I only saw 1 Beckett Commodore and I remember the axial flow. I do remember not being impressed with the fire0
Steamhead just being Steamhead as always willing to help!
And much thanks to you Dan as its this site that facilitated my eventual meeting with Steamhead in the first place. It’s a small world 😉DanHolohan said:I love this story.
It is, Gerry. Thanks.Retired and loving it.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
