Thermostat
Andrew boiler
Member Posts: 44
Hi I am having problems with my Honey well PRO Non-Programmable Digital Thermostat (1 Heat don't know when I will need to get new. Bat tiers I think it's hard wire can any one help me
Kinda tough to do
when you give no indication at all as to what your problem is.Br. Jamie, osb
This is the 12th thread you've started in one week
about your thermostat. ****?0 -
Complicated
Two wires AND a knob, no end of mischief can come from something like that.
3PSI gauge0 -
Buck up
I think you either need to give a complete description of the components and the issue you are having or buck up and do some reading.
No one can help you if you are not specific.
A drawing would help.
Albert Einstein0 -
Update
I posted having problems with my PRO Non-Programmable Digital Thermostat (1 Heat
I have my own zone in my master bed room and it's saying it's 71 in my room it's set at 68.
Is there anything I can do to save service man to come on a Sunday?0 -
Wire
What is the other end of the wire attached too?
Do you have and know how to use a multimeter?
Albert Einstein0 -
Wire
No I don't know how to use a multimeter0 -
What happened
When did it stop working?
Is this a new t-stat?
The wire goes to your mechanical room. Can you post a picture?
Albert Einstein0 -
over shoot...
it may just be that the boiller fired off and it ran the heat into the room and it is now there trying to get out the emitter as quick as it can , if you are in an apartment buildingg most likely you are thinking to open a window ...dont. it is probably not your thermostat per se.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
