Thermostat
Hi I am having problems with my Honey well PRO Non-Programmable Digital Thermostat (1 Heat don't know when I will need to get new. Bat tiers I think it's hard wire can any one help me
    Jamie Hall Member Posts: 23,324
    Kinda tough to do
    when you give no indication at all as to what your problem is.
  • SWEI
    SWEI Member Posts: 7,356
    This is the 12th thread you've started in one week
    about your thermostat.  ****?
  • BobC
    BobC Member Posts: 5,478
    Complicated
    Two wires AND a knob, no end of mischief can come from something like that.
    Bob
    3PSI gauge
  • Zman
    Zman Member Posts: 7,569
    Buck up
    I think you either need to give a complete description of the components and the issue you are having or buck up and do some reading.
    No one can help you if you are not specific.
    A drawing would help.
    Carl
    Albert Einstein
  • Andrew boiler
    Andrew boiler Member Posts: 44
    Update
    I posted having problems with my PRO Non-Programmable Digital Thermostat (1 Heat
    I have my own zone in my master bed room and it's saying it's 71 in my room it's set at 68.
    Is there anything I can do to save service man to come on a Sunday?
  • Zman
    Wire
    What is the other end of the wire attached too?
    Do you have and know how to use a multimeter?
    Carl
    Albert Einstein
  • Andrew boiler
    Wire
    No I don't know how to use a multimeter
  • Zman
    What happened
    When did it stop working?
    Is this a new t-stat?
    The wire goes to your mechanical room. Can you post a picture?
    Carl
    Albert Einstein
  • Weezbo
    Weezbo Member Posts: 6,232
    over shoot...
    it may just be that the boiller fired off and it ran the heat into the room and it is now there trying to get out the emitter as quick as it can , if you are in an apartment buildingg most likely you are thinking to open a window ...dont. it is probably not your thermostat per se.
