Thermostat upgrade
I have a hot water system with cast iron radiators. These are the two thermostats that control both zones. I would like to upgrade them to maybe some digital/programmable thermostats? What are some alternatives ?
Those thermostats are made for line voltage electric hear. (110v. or 220v.) but that does not mean that someone used the incorrect thermostat for a 24 volt circuit. Do you know what the other end of the thermostat wires are connected to?
What is important is the heat cycle for hydronic heat with cast iron radiators .. As Ed mentioned yours are line voltage thermostats used for electric heat . The last good line voltage hydronic heat thermostat was the early model T451 . I have been using the Honeywell TL8100 .Check the voltage it would be nice if it were 27V , you would have so many better options …
Long Island ?
Not onl line voltage thermostats — but looks to me to be line voltage wiring as well. As @EdTheHeaterMan asked, what's at the other end? And before you start poking fingers in there, please use a non-contact voltage tester to verify that the power is off.
please let a contractor test it
Non contact testers are questionable.
we’re actually not allowed to use them due to false negatives0 -
Hmm… I've never had a false negative with my Klein…. maybe I've just been lucky?
You've been lucky. They're mostly reliable, but that last little bit is what bites!
Hopefully everything was converted to low voltage at the boiler. If it was, whatever thermostat you get needs a backplate big enough to cover the Gem box.
- 135 Chimneys & Flues
- 16.2K Strictly Steam
