Thermostat upgrade
I have a hot water system with cast iron radiators. These are the two thermostats that control both zones. I would like to upgrade them to maybe some digital/programmable thermostats? What are some alternatives ?
    EdTheHeaterMan Posts: 13,018
    Those thermostats are made for line voltage electric hear. (110v. or 220v.) but that does not mean that someone used the incorrect thermostat for a 24 volt circuit. Do you know what the other end of the thermostat wires are connected to?
    Big Ed_4
  • Big Ed_4
    Big Ed_4 Posts: 3,589
    edited 10:02PM
    What is important is the heat cycle for hydronic heat with cast iron radiators .. As Ed mentioned yours are line voltage thermostats used for electric heat . The last good line voltage hydronic heat thermostat was the early model T451 . I have been using the Honeywell TL8100 .Check the voltage it would be nice if it were 27V , you would have so many better options …
    Long Island ?
    Jamie Hall Posts: 28,004
    Not onl line voltage thermostats — but looks to me to be line voltage wiring as well. As @EdTheHeaterMan asked, what's at the other end? And before you start poking fingers in there, please use a non-contact voltage tester to verify that the power is off.
    pecmsg Posts: 7,653
    edited 9:51PM
    please let a contractor test it
    Non contact testers are questionable.
    we’re actually not allowed to use them due to false negatives
    edited 10:04PM
    Hmm… I've never had a false negative with my Klein…. maybe I've just been lucky?
  • ratio
    ratio Posts: 4,347
    You've been lucky. They're mostly reliable, but that last little bit is what bites!
    HVACNUT Posts: 7,810
    Hopefully everything was converted to low voltage at the boiler. If it was, whatever thermostat you get needs a backplate big enough to cover the Gem box.
