TigerLoop instalation for Bio Fuel 100 rating
Interested in knowing what peple have found out there when upgrading to a B100 rating.
I'm finding descrepences when sourcing braided hoses (36"). Suppiler has one number, manufacurer gives another. Catalog states one rating, and sales info states another. Then you can not find them...
Talk to most techs, you get, I use these, never had a problem...
BioFuel is going to be up to 50% by 2030, it dosen't seem anyone is gearing up for it... looking at the $$ service work when things crash maybe?
Thanks!
  • HydronicMike
    HydronicMike Posts: 477
    Pipe them in copper. Tiger loop instructions call for replacing the Tiger loop after 10 years. I don’t recall seeing an expiration date on the standard flexible supply house hoses.
    But I stopped using them as they would crack at the connection when flexing them while servicing the pump strainer.
    I either use Ruby Reds (7 year recommended replacement) or run them in copper, leave them connected and unbolt the pump when I need to swing open a boiler door.
    EdTheHeaterManProdiy1
    EdTheHeaterMan Posts: 13,030
    I Thought I invented the removing pump procedure back in the 1990s, before swing out doors were a thing. I needed to do that for replacing combustion chambers before unbolting the fire door.
    Should of got the procedure patented back then. DOH! 🤷‍♂️.
    HVACNUT Posts: 7,815
    I haven't had any need to look yet, but my suppliers are offering B100 compliant. Whether or not they're in stock is another story. I'll jump off that bridge when I get to it.
    I've never had any major issues with braided oil line.
    You're supposed to add a 🤪 or something at the end to let us know you're kidding.
  • Prodiy1
    Prodiy1 Posts: 4
    Thanks for the input!
    Every vendor sends the same info, (I had it before I started this project). I asked numerous to physically go look at the label... guess they have reading problems, ha ha
    Contacted Beckett, tech guy gave me another number, has to be right, he's the tech guy, right. 😁
    Vendors would not even contact the guy, just, nope, no listing.... then they send the catalog page...
    There are companies that make Bio100 compatible hose, Gates, and Parker are 2. Pretty sure the braided covering can be added.
    This has been an education...
  • Prodiy1
    Prodiy1 Posts: 4
    An FYI update.
    The only place I have found that the documentation seems accurate is on tje packaging, and hose label of the TigerLoop S223-36.
    States: No 1 & 2 Fuel Oil, "UP TO B100"
    Package has production date.
    Hose has "Limited Warranty Expires" date.
    Unfortunately, vendors, and manufactures wete not interested in providing the answers. Another brand was the hoses were stiff, these are pliable.
    Another bit, I seems the higher blend ratios can effect copper, and brass... but it seems that's not being addressed...
    Just thought I'd share...
  • HydronicMike
    ”…Another bit, I seems the higher blend ratios can effect copper, and brass... but it seems that's not being addressed...”
    I wouldn’t worry about it, for now. Brookhaven Laboratory along with NORA published a report about it. It does affect copper and brass, but the conclusion was basically not enough to worry about on a single pipe residential system.
    Would probably be a concern on a large commercial system.
    Is this a case of planned obsolescence? At least my son will still have a job until he reaches retirement age.
    pecmsg Posts: 7,656
    Replace the flex hose with the tried-and-true Copper Loop.
    Robert_H
  • ChasMan
    ChasMan Posts: 476
    edited June 19
    I was hoping to make my system B100 ready but ran into a few issues. B100 rating does not apply to the oil burner for starters. At least not mine, Riello F3, it has a B20 rating. For B100 it probably needs to be replaced with one of the gulliver models as it requires some special safety sensors. Also, firomatic valves are only B100 rated if they are new enough according to Beckett. They claim that some suppliers may still list them as B20. Mine was made in 2025 / 06 and doesnt mention B20 or B100 on the package and neither did the on that came with the B100 rated tigerloop. The tigerloop brand hoses appear to be B20 rated and I can't find a non hardening thread sealant rated for B100 either. So here we sit.. at least it is all B20 rated now. They started using B10 here last year and B15 slated for 2030.
    Prodiy1
    Jamie Hall Posts: 28,006
    While you're at it, don't overlook your o-rings and gaskets. The only material I would use for anything much over B10 is fluorosilicone (same thing applies to you gearheads out there — anything over E10 and you MUST use fluorosilicone).
  • ChasMan
    ChasMan Posts: 476
    I think the industry is using Viton (FKM) and not fluorsilicone. At least thats what Becket advertises.
  • Prodiy1
    Prodiy1 Posts: 4
    edited October 15
    So it seems the industry/trade & states pushing BF still has no clear direction on bio fuel increase. Uneducated, or just don't care...
    I've asked a lot of people (homeowners) if their oil guys discussed bio fuel... nope. They tell them don't worry about it. Still using old steel, dirty tanks, seeing more leaks, then replace with steel. Sounds like the guys that left the automotive bussiness when Ethanol came into play for auto and marine use. Automotive went Vinton (green) seals.
    You think the filter companies would just go green on the "O" rings, nope to easy, why cut inventory and stock numbers….
    Someone mentioned thread sealer for fittings, another issue. Received the most non-answers, from the (some) manufactures, "It should be fine". It's a shame that manufactures and vendors don't have clear answers... even the big guys.
    It's comical when a "big vendor" looks at you and says, "you're not a heating professional", and you pull out the documentation and they're like, we don't have time to review everything, and then question a manufacture about their own information... you're ignored, "how dare you question us for lack of documentation".
    I finally acquired the components I need for my upgrade, all labled correctly. Then long and behold the almighty Beckett comes out another new Bio Fuel system, plus a show (webinar). I personally didn't think it give enough pertaint info for the guys in the field, just gave more questions.
    This isn't rocket science people... or maybe it is for some.
    The automotive somewhat got through it, or got out of the trade. Hey oil guys don't have fuel injection to deal with, know a few auto guys that went into the oil buss.
    Just some stray observations, opinions, thoughs .…
