Location of thermostat low voltage.
How can you find the low voltage source to a thermostat that powers several wall heaters. No central system just the thermostat and the heaters. I am thinking maybe the same transformer as the door bell but that works. 1982 home. I replaced the mercury thermostat but still not working.
Thanks Frank
If the thermostat is low voltage there is a transformer somewhere unless the equipment is a POWER PILE system where voltage is generated by the gas flame.
Is it several wall heaters with one thermostat? If so, look in each heater. I assume that there is 120 volt in the heaters to run the fans.
If the transformer is in the basement, then look (usually) around the breaker panels
Low-voltage HVAC control transformers are 24 V. Doorbells are 16 V. They are not interchangeable, and I've never seen one transformer used for both purposes.
Bburd0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
