Location of thermostat low voltage.
How can you find the low voltage source to a thermostat that powers several wall heaters. No central system just the thermostat and the heaters. I am thinking maybe the same transformer as the door bell but that works. 1982 home. I replaced the mercury thermostat but still not working.
Thanks Frank
If the thermostat is low voltage there is a transformer somewhere unless the equipment is a POWER PILE system where voltage is generated by the gas flame.
Is it several wall heaters with one thermostat? If so, look in each heater. I assume that there is 120 volt in the heaters to run the fans.
If the transformer is in the basement, then look (usually) around the breaker panels
Low-voltage HVAC control transformers are 24 V. Doorbells are 16 V. They are not interchangeable, and I've never seen one transformer used for both purposes.
Bburd0 -
First problem is that you replaced the mercury thermostat. If it wasn't actually broken, it was superior to any other non-smart thermostat you could bu — at any price.
But what's done is done.
Now the next point is that a simple thermostat — like the mercury one you junked — is just a switch. It does not need a power source. It is possible the the device it controls needs a power source to operate — most do — but all the thermostat does is close a circuit. The controlled device is where the transformer would be — if there is one. If a single thermostat is controlling several devices, there may be relays taking the thermostat signal to transmit the call for heat on to the devices — in which case there would be a transformer. probably near the relay, to power the relay.
