Location of thermostat low voltage.
How can you find the low voltage source to a thermostat that powers several  wall heaters. No central system just the thermostat and the heaters. I am thinking maybe the same transformer as the door bell but that works. 1982 home. I replaced the mercury thermostat but still not working.
Thanks Frank
    EBEBRATT-Ed Posts: 21,328
    If the thermostat is low voltage there is a transformer somewhere unless the equipment is a POWER PILE system where voltage is generated by the gas flame.
    Is it several wall heaters with one thermostat? If so, look in each heater. I assume that there is 120 volt in the heaters to run the fans.
    If the transformer is in the basement, then look (usually) around the breaker panels
  • HomerJSmith
    HomerJSmith Posts: 2,837
    What kind of heating sys do you have? Electric baseboards are different than hot water baseboards, etc.
    Belltfrank
  • bburd
    bburd Posts: 1,338
    Low-voltage HVAC control transformers are 24 V. Doorbells are 16 V. They are not interchangeable, and I've never seen one transformer used for both purposes.
    Bburd
    First problem is that you replaced the mercury thermostat. If it wasn't actually broken, it was superior to any other non-smart thermostat you could bu — at any price.
    But what's done is done.
    Now the next point is that a simple thermostat — like the mercury one you junked — is just a switch. It does not need a power source. It is possible the the device it controls needs a power source to operate — most do — but all the thermostat does is close a circuit. The controlled device is where the transformer would be — if there is one. If a single thermostat is controlling several devices, there may be relays taking the thermostat signal to transmit the call for heat on to the devices — in which case there would be a transformer. probably near the relay, to power the relay.
