Propress...this is leaking right?
Have it repaired with new copper pipe, fittings and lead free solder.
it could be lack of proper prep on the tube, or the tool out of calibration
Even with a proper press, they sometimes develop micro leaks. Glycol seems to be more prone to that green fuzzing
An opinion from one manufacturer on glycol systems
I don’t see the dimples on the fitting to show that it was pressed properly.
might be able to clean it up and re-press it but it’ll probably have to be cut out0 -
@HydronicMike , no glycol in the heating system.
@pecmsg , the dimples are there, just hard to see due to the black staining. To me, they look the same as the dimples on the fitting above it.
This was installed about 6 years ago and I do not recall ever seeing the green residue. I recall black staining on the pipe but not on the fitting itself….I always though the black was from a sharpie.
Thanks, FloMo
All…I wiped away some of the residue from one side of the fitting. This should give you all a better vantage point. Thank you all, FloMo
Thank you all. You are all so very helpful and it is very much appreciated.
Flo
I was taught if it isn’t dripping it’s not a leak! 😂.
i’ve seen that type of corrosion on pro , none of which leaked. Maybe originally and self sealed, or got repressed, who knows0 -
Carefully use a Scotchbrite to clean off the connection. Many sharp edges on press fittings.
If the oxidation returns you have what might be considered a micro leak.
Two 45's and a short piece of tube would be an easy replacement for that ell.
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
