0-3 PSI Gauge
What the specifications for the correct gauge? I found a Sensor and Control (YE-6FDL04.0/3#) however in the specifications i says medium temp max is 140 degrees…and ambient temp from -4 to 140 degrees. I assume these specifications are not going to be sufficient.
Any suggestions a reliable mfg?
Thanks.
i guess the specs pertain to what you are measuring and what it's for. So what are you trying to do?
Having trouble finding a low pressure gage for steam that DOES NOT come with a stem.
I am trying to get a 0-3psi gauge for my Peerless steam boiler.
So far I have found 0-3psi with specification of 140 degree Fahrenheit max and a 0-3psi with specification to handle steam but it has a 2” stem.
I am going to start with a 90 degree pig tail then a tee so I can have both the 0-3psi and the 0-30psi.
plenty of online gauge suppliers. The more you spend the better the quality and accuracy
Living the hydronic dream1 -
Thank you gentlemen.
If your gauges are sufficiently above the top of the boiler even without a pigtail they won't see steam if the piping is air tight, there will be a cushion of air in the piping.
If interested:
0 - 2" Magnehelic without pigtail, with and without snubber
https://forum.heatinghelp.com/discussion/158333/0-2-magnehelic-without-pigtail-with-and-without-snubberSteam pressure. Single pipe steam heat operating at very low pressure.
One Pipe System2 -
one of these and a pigtail works well for me
https://www.supplyhouse.com/Winters-Instruments-PLP305-2-1-2-PLP-Steel-Low-Pressure-Gauge-1-4-Bottom-NPT-w-Brass-Internals-0-5-PSI
Depending on what you want or expect to see with your low pressure gauge, you may want to know the actual boiler's / system's operating pressure. My system never goes over 2 Inches of water column so with a 0-3 PSI gauge it would never go past the red line I added to the gauge image.
One Pipe System0 -
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
