Control needed
does anyone have a suggestion on an in expensive controller, brand doesn’t matter that can be powered with 24vac, accepts a 10 k sensor (supply air) that has two normally open contacts? Make on temperature rise. One contact is necessary, but two stages (two contacts) would be preferred. I need to temporarily get a 100% OA unit working until the OEM controller can be installed. It is an older unit and the controller while still available has a long lead time. Thanks to all
    hot_rod Member Posts: 28,250
    pretty much all electronic setpoint controls are multi voltage and available as multi stage
    They come with a sensor, not sure if it can be switched
    Ranco, Honeywell, Penn, Johnson Controls are some of the brands
    Choosing heat or cool is what differentiates break on rise or fall
    zepfan
    109A_5 Member Posts: 4,376
    edited 3:24AM
    Omron may have something you like.
    https://automation.omron.com
    Many temperature controllers out there.
    Many modern temperature controllers you can pick the temperature monitoring device from a menu like NTC Thermistor, Thermocouple (J, K, other), RTDs, etc.
    Sadly the Ranco unit above does not specify the electrical characteristics of the sensor it uses.
    " accepts a 10 k sensor (supply air) " Using an existing sensor may have unexpected results.
    I think the TSS2-2400 checks all your boxes, you will have to program it .
    TSS2-2400
    Dual stage temperature switch, °F, 24 VAC/DC.
    Dwyer-Omega
    LOVE CONTROLS DIVISION
    www.love-controls.com
    DWYER INSTRUMENTS INC.
    https://assets.dwyeromega.com/manuals-do/TSS2_Instruction_Manual.pdf
