Pressure testing and leak help
chippy2
chippy2 Member Posts: 26
edited 12:30PM in Radiant Heating
hi.
I just added 3 radiant zones w/manifold and pressure tested that section with 40psi overnight and all good.
Separately I had to replumb and create a primary/secondary loop for baseboard zones. I pressure tested that section separately with 25psi incl boiler and it didn’t hold over night. I used soapy water every joint and nothing! Wondering if relief valve or air escape valve (closed) could be the culprit?
Also did find/fix one threaded leak at the new 3 way mixing valve I added and retested. Do you usually pressure test older systems after adding plumbing upgrades?
Any ideas on locating air loss/leak before I fill it?
