Rust on Fill and Vent Pipes
charlie123
in Oil Heating
Hi all, the attached image shows some rust on the piping to my recently-installed oil tank.
Assuming that the rust won't limit itself to being only a thin coating on the surface and needs to be addressed, what should I have the installer do?
Would a light sanding followed by silicone or paint take care of it?
Thanks for your help
That rust is surface. After a few decades it might eat a little into the fittings… after a century or so they might leak.
If you object to the look of it, get a small wire brush and brush it. Then spray on a coat of Rust-O-leum rusty metal primer, then a coat of whatever colour you fancy.
Thanks Jamie.
Are those cast fittings?
No one is piping oil tanks in stainless steel that I ever seen.
- 133 Chimneys & Flues
