Streetside Incoming 1" copper pipe crushed by contractors
2»
    pecmsg Posts: 7,621
    just like the gas companies
  • Mad Dog_2
    Mad Dog_2 Posts: 8,747
    If its inside the building footprint and you have the opportunity to have access to it, why wouldn't you? Its still a mechanical joint and could start to leak - back up in to the building- down the road.Mad Dog
    leonzEBEBRATT-Ed
    mattmia2 Posts: 18,272
    if i'm keeping score right, it is under an exterior entry doorway with some stairs or similar leading to it
  • Charlie from wmass
    Charlie from wmass Posts: 4,431
    The water service fitting with the rubber gasket and the 5/16 inch locking ring are rated for underground repair. They are superior to a flare on Old piping because the process of flaring the pipe can cause fractures around the flare. Copper becomes work hardened. Also the interior surface of the pipe becomes pitted with normal use and a flare is a metal to metal seal which is greatly compromised if the surface of the pipe is less than brand new. This is why most water companies in the Northeast do not use flared fittings on repair of old work. In my area of Massachusetts this has been standard practice for over 35 years. My father who bless his soul started the trade in the 1950s was hard to convince that flair was not Superior to what he referred to as a dresser coupling. A dresser coupling does not have the lock ring that an underground water service fitting has.
    cell # 413-841-6726
    ethicalpaulChrisJbranimal
  • branimal
    branimal Posts: 304
    Great explanation on why a flare would not have worked. Thanks.
  • jumper
    jumper Posts: 2,625
    »I would replace the line, will be costly.« For a rental building crucial question, especially in places like NYC, is whether one can categorize it as a repair?
