Well... we gotta leak.
Tom_133
Tom_133 Posts: 990
Sooo, I installed a 4" copper main on a very large building, and because I had a minor lapse in judgement I decided to solder it. No need to say it, I wont do it again. Next time it will be press, or victaulic, or welded, but not soldering over 3" ever again. It's not that we are not capable, just read on.
I pressure tested it and it held the 100lbs like a champ. Then after one winter it sprang a leak. I get it, I understand it, no need to explain why it happens, or what I did wrong I am very sorry and again I wont repeat this mistake.
Now, the question is with a tight space, and 4" fittings, has anyone successfully pulled apart, cleaned, refluxed and soldered successfully? I can get it pretty dry and I wont do this until June so I got all day to repair, but want to get it right. I would be happy to get the right torch head if anyone has suggestions on that as well. Out of the 20+ joints we got one weeper, well two if you include me.
Thanks
Tom
Tom
Montpelier Vt
    pecmsg Posts: 7,613
    Pro Press.
    Steve Minnich
    hot_rod Posts: 28,524
    edited May 13
    on large sizes like that you can pre-tin the tube and fitting. Basically wiping solder around the pipe and fitting first, then assemble.
    If it is no too close to other fittings you could silver solder over the fitting.
    Blockade is a good rod for that use.
  • Most of our copper work is in 2-4" and we never sweat anymore unless a property specifically wants it. You need a lot of heat for 4", so we would typically do two torches at once, one on each side. There are fancy round pipe torches, but we never had those.
    Steamhead Posts: 18,974
    Maybe rent one of those fancy round torches?
    Semi-retired
  • Mad Dog_2
    Mad Dog_2 Posts: 8,746
    Without re-soldering it, I would silver braze right over it. As long as you're not going to burn anything next to it, its the fastest, easiest fix here. Mad Dog
    HydronicMike
  • Mad Dog_2
    edited May 13
    Do you have a photo of the joint and situation? What's also great about silver brazing is that you can drill a small hole at 90 degree 6 o clock position and drain any residual standing water. That hole will be the last part you will braze close. Also, you don't need a Large Rosebud tip or Oxy-Acetylene on 4" Copper. A large Turbotorch tip and a Full B Tank and youre good to go. Mad Dog
  • Tom_133
    Tom_133 Posts: 990
    no pics yet. But man I appreciate the help. I may just braze it up!
    Tom
    Montpelier Vt
  • Mad Dog_2
    DM me or call if you need any tips. I've been in your shoes many times and silver-brazed up to 12" Pipe. 516-322-2881
    bjohnhy
  • pedmec
    pedmec Posts: 1,488
    Cut it out and propress. You wont regret it. When you get done your gonna wonder why you didn't propress it to start.
    And yes, i have taken plenty of sweat fittings apart, cleaned them, and resoldered successfully. But i wouldn't do it anymore because of propress. Propress is just to simple. The problem with large size sweat fittings is sometimes the interference fit is a little to large to hold the solder. If not properly aligned the gap is larger on one side than the other. Tinning definitely helps but its and added process the adds labor. Add that all up and a propress fitting doesn't seem that expensive anymore. Priced right and the customer is paying for it anyway.
    Good luck
    mattmia2 Posts: 18,233
    the cost of the solder that goes in to a joint that size isn't trivial either.
  • RascalOrnery
    RascalOrnery Posts: 158
    What the blazes is 4" copper used for? Water supply for the whole town?
    larger commercial building especially if it has a lot of bathrooms with flushometers. most of our campus buildings have 4" supply or more.
    GGross
  • Mad Dog_2
    edited May 13
    This is a callback, correct? You're already in the Red. A 4 inch Press Tool and fittings are big bucks. If you want out of there, for the cost 3 or 4 sticks of Silver Solder and some acetylene, you can move on. Mad Dog
    EBEBRATT-Ed Posts: 21,169
    Since it lasted a year do you think you could have an expansion issue? How long of a run is it? Subjected to temperature swings?
    If you silver solder or braze it you don't have to pull it apart.
    If you propress your going to need an elbow which may be all you need if you sawzall though the 4" sweat 90 and unsweat and wipe the solder off both ends of the pipe and maybe trim some off as the PP90 is long radius.
    Thats assuming you can move the pipe that much. Otherwise you going to need a 4" coupling or two.
    I had the same situation except it was a 4" main in a insurance building that feed 2 3" lines at the end of the run.
    It was all propress. I didn't install it but I was the one that had to fix the only leak. Had to waste out 1 3" 90 and 2 3" 45s
    You or anyone can have a leak no matter what method you use.
    Victaulic is expensive especially for copper and you will find the fittings are hard to find.
    at 4" cast iron probably will not scale enough to restrict the flow so that is also an option.
    looks like propress and vitaulic are about the same price once you buy all the clamps although vitaulic is reversable.
  • Tom_133
    Tom_133 Posts: 990
    There are 3- 400k boilers lined up feeding a building with a 3" header, they wanted room for future indirects on it so we added the two tees on either side of the closely spaced tees. So there are not that many joints.
    I know we dont discuss pricing, so I wont get to deep into that but press isn't scaring me, I own all the tooling. The stupid insulation cost me a pretty penny and HATE the idea of paying for that again. I am going to go put my eyes on it and will probably consider brazing all the 20 joints.
    These are good customers, so it's possible they dont want a future worry, so it may get pressed and I may just do the labor for free.
    Tom
    Montpelier Vt
  • Mad Dog_2
    edited May 14
    Tom. Have a little faith in yourself. Its highly unlikely you'll have another leak like that from your soldered joints. It would've happened already. Mad Dog
    bjohnhy
    Oe time I had to solder over some joints on 4" copper in a year old hotel! It was the got piping and I think the expansion/ contraction caused the leaks.
    I used a rosebud tip but with oxygen/ acetylene, which heated very quickly.
    But if you have the press equipment or can borrow the large jaw fro a wholesaler, go that route and be done quickly.
  • Tom_133
    Tom_133 Posts: 990
    Thanks again all!
    Tom
    Montpelier Vt
  • Intplm.
    Intplm. Posts: 3,156
    If you soldered it first, don't braze it; brazing over soldered joints can open up a whole new can of worms. So, pick your poison. Solder it where it leaks, and solder the entire joint again, or pro-press it.
    One thing I have done in the past after soldering a large joint is to take my smallest turbo torch tip and cap the joint off so it looks factory done. It can look clean and without any runs, and if done right, will show a visually smooth finished joint. One other thing, do not touch all of your other joints. They should be fine.
  • Mad Dog_2
    Just curious? What Can of Worms 🪱 are we talking about silver-brazing over a Soft-soldered joint? Done it many times without an issue. Mad Dog
    Yeah. I have brazed over solder joints as well with no issue
  • Steve Minnich
    Steve Minnich Posts: 2,964
    20 joints? There’s a sure solution and then there are less than sure solutions. If you already have the ProPress tool and the 4” jaw and it’s a good customer, I’d be pressing it every single time. Cutting the insulation carefully should avoid having to bring the insulator back. Just my .02. Brazing 4” needs a lot of heat and added risk.
    Steve Minnich
  • Intplm.
    A can of worms, you ask? It stinks, as a can of worms does.
    Sorry, lol, if this metaphor shows my age. I also have brazed over a solder joint, but not one this large of a diameter, and not one with water in it, as this 4" pipe will surely have some residual water in it, which can surely cause a problem.
    @Tom_133 If you do not have the room to propress this repair, try soldering first. If that doesn't work propress the thing and walk away. At this point, only you can measure the difficulty in terms of time and cost. It's like what my doctor might ask. "On a scale of one to ten, how would you rate the pain?"
    I also like the comment from @Steve Minnich above.
  • Tom_133
    Tom_133 Posts: 990
    I can get a very high percentage of the water out. That isn't a factor for me.
    If I do the math based on Supplyhouse.com the fittings for the press will be about 3k, so thats a little rough if I can just braze a fitting or two.
    How do people feel about brazing and already soldered joint?
    Tom
    Montpelier Vt
  • Intplm.
    Well, if you can get the water out on a large 4" fitting…go for it.
    edited May 18
    I have braised over leaking solder joints mostly on refrigeration piping.
    If you can get that not to leak water is a piece of cake
    Also, you don't have to cook the entire joint up to temp at the same time. You start in one spot (usually at the top for me) and work your way around.
    Mad Dog_2Intplm.
  • Mad Dog_2
    What's great about Silver-Brazing is that its so plastic in its molten state that you can bridge large gaps and holes. When you are done Silver-Brazing a joint, it is very obvious, visually, if you have a joint that is not going to leak unlike soft solder where you may have a tiny pinhole leak that is naked to the eye. Mad Dog
  • rick in Alaska
    rick in Alaska Posts: 1,530
    I worked on a retirement home before propress came, out where the contractor brought in a 12" copper main, and had a leak on the 90, which they just cut out and replaced. I'll bet they never thought about just brazing it up, which is a great idea by the way. I heard the 90 was $1200.00 at the time.
    Rick
    Mad Dog_2
  • Tom_133
    Tom_133 Posts: 990
    More proof that as bad as it may seem to me, someone out there has it worse!
    Tom
    Montpelier Vt
    Mad Dog_2
  • Mad Dog_2
    edited May 26
    During my plumbing apprenticeship and the first year I turned out with my tools (Journeyman), the outfit I worked for had a shop and office in Rockefeller Center, New York City. We had the service and repair contracts for Radio City Music Hall, The Rainbow Room, Atlantic Records. NBC Studios, Hurley's Saloon, Saint Patrick's Cathedral and the Cardinal's Residence, Time Life Building, The International Building, Celenese Building, Prometheus Restaurant and Rock Center Ice Skating Rink, and the whole complex of 50 plus story buildings in the Rock Center Complex (several City Blocks). My primary mentor was the shop foreman, Dublin-Born Jimmy O'Brien, a 5 foot 5 Ball of fire with encyclopaedic plumbing and heating Bona Fides and skill-set.
    Between the elite clients we had ($$$) and working marathon shifts (sometimes 20 hours at a clip) with Jimmy, I couldn't have had better Ring experience. I got to see and work on systems and pipe sizes the vast majority of plumbers never do - a Blessing! Keep in mind, we HAD to be able to get these Iconic New York City destinations fixed and up and running by Curtain Time. Mad Dog
    ratioEBEBRATT-Edrick in Alaska
