Old lead-free Taramet Sterling Solder
I forgot to check my dad's old plumbing box before soldering up the heating/plumbing pipes for my combi boiler. Turns out there's almost a full spool of Taramet Sterling in there.
Did they change the formula for the 2011 low-lead requirements, or is this still good for potable water pipes? I'm running out of my new Harris Sterling.
3 -
i assume they changed the formula in like 1986…
You're good to go unless you live in California....they MAY have changed there thresholds. By the way, Taramet Sterling has been my favorite solder for many years. Mad Dog
2 -
Thanks. It looks like it was set to 0.2% in 1986 and remained unchanged in 2011, with the 2011 rules mostly impacting fittings <0.25%.
Do they still sell Taramet? Maybe under Harris? Label looks like my Harris spool.
Slivabrite is excellent also, Taramet Sterling has a better pasty range and caps best of them all. Mad Dog
Apparently 95/5 isn't eutectic, but maybe it has a more narrow point than leaded solder?
Eutectic solder is nice because you can't accidently move something while it's setting up and cause a questionable joint, it's either liquid or it's not. This is probably less of a concern in plumbing than electronics.
When I was a First Year Apprentice in 1985, we soldered with 95/5 and Capped with 50/50. Mad Dog
the viscosity of the liquid changes with temp as well.
63/37 is supposed to be eutetic 60/40 is close, 50/50 has a big range where it will turn in to a mass of crystals if you move it. 50/50 also has a noticeably higher melting point if you've eve worked on old electronics that were soldered with 50/50
I believe you.
Nothing fills gaps like 15% silphos tho.
If it says lead-free on it, you are covered. If it doesn't, do not use it on potable water.
When 50/50 was used for all soldering needs, I remember being able to solder a vertical joint with solder running UP! without any drips running down. I cannot and haven't seen it done since.
maybe that is just poor tolerance of fittings. the capillary action should draw it up but the closer temp between where the soler melts and the flux burns becomes important there too.
I agree.
As long as the fitting and joint are the hottest part I'd expect it to suck the solder up.
I still do that with Stay Brite #8
Should someone have a rant about how only hacks use Straybrite?
I have a spool of it above my desk, the only reason I didn't use it so far was laziness. I didn't feel like cleaning all of the fittings and dealing with flux.
I used to hate to solder a vertical up.
The trick is to keep the heat up high. Too much heat down low and it will run down.
But most of you already know that. Like most people I probably use too much solder as well.
1/2" of solder for a 1/2" pipe. 3/4" for 3/4 etc.
I tell myself that and still use to much
2 -
I remember those pre-solder copper fittings , they came with ring of solder inside .. I still ran a roll and "wiped " each connection :)
I've seen similar fittings for soft solder as was an an incorporated brazing ring in the cup. Mad Dog
I saw those at home depot a long time ago. I assumed it was to help homeowners solder.
or to heat the fitting evenly so the flux didn't burn out of part of it before other parts got hot enough to melt the solder
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
