Old lead-free Taramet Sterling Solder
I forgot to check my dad's old plumbing box before soldering up the heating/plumbing pipes for my combi boiler. Turns out there's almost a full spool of Taramet Sterling in there.
Did they change the formula for the 2011 low-lead requirements, or is this still good for potable water pipes? I'm running out of my new Harris Sterling.
i assume they changed the formula in like 1986…
You're good to go unless you live in California....they MAY have changed there thresholds. By the way, Taramet Sterling has been my favorite solder for many years. Mad Dog
Thanks. It looks like it was set to 0.2% in 1986 and remained unchanged in 2011, with the 2011 rules mostly impacting fittings <0.25%.
Do they still sell Taramet? Maybe under Harris? Label looks like my Harris spool.
It says lead free right on the spool.
I like Silvabrite 100.
Who would have thought solder would be $50 and up.
Supply House has 60/40 solder with lead for less than $30
every time i have bought solder even in the 90's i have thought it cost 10x what it seemed like it should.
- 120 Geothermal
