what kills ball valves
minerals
I don't think you can point to any one specific thing. Lack of use certainly doesn't help, though. Mineral buildup on the ball, if it's not fully open, won't help — but periodic use should keep that to a minimum. On the other hand there are some chemicals — even additives in water, if in high enough concentrations — which can attack some seals materials. But I'm not sure you'd ever see concentrations high enough to be a problem in most of our work.
Letting them sit for years without being touched building up minerals etc
Also rust / grit from steam boilers from my own experience.
Use good valves and exercise them every 6 months and they'll outlast most people.
seize up, break, leak??
Misapplied, installation error, over-heating a sweat valve.
Water quality, aggressive, high mineral content
Fluid temperature, higher temperature, more minerals precipitate
Lack of use
Quality of valve construction, low quality alloy, thin forgings
Manufacturers quality control
Getting OT, but can anyone recommend a specific brand and model of ball valve that will last more than 6 months on a well system with ~ 6.5ph water? The failure mode is the shaft inside the ball corrodes and the valve can't be turned fully on or off. The valve is right off the tank manifold so it's before the acid mitigation tank.
Curious if someone makes an inline valve like the stops I've seen that have a plastic shaft. They seem to hold up very well in general.
Not leaving them fully opened, or fully closed.
Maybe a globe or gate valve is a better option. They are less prone to sticking. Exercise it a few times a year.
Quality valves are easy to spot, thicker forging, packing nut. Apollo Watts, Nibco still build some better valves in the US.
Jomar has a quality Italian valve line.
The more you work it , the better the chance of it working when you need it.
The Caleffi LegioMix is a ball type mixing valve and once a day it rotates all the way around, to wipe scale off.
valves used on potable water need to be LL, low lead. It will be dezincified brass also, so they are better alloys for low ph water.
Stainless or plastic valves are an option. Plastic would be most tolerant. Maybe a schedule 80 quality pvc gate valve?
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
