what kills ball valves
jumper
jumper Member Posts: 2,603
Too much use or lack of exercise?
    mattmia2 Member Posts: 17,902
    minerals
  • Big Ed_4
    Big Ed_4 Member Posts: 3,561
    Crappy valves ?
    EdTheHeaterMan Member Posts: 12,658
    cereal killers?
    kcoppRobert_HIntplm.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,716
    Steam condensate does. Mad Dog
    Jamie Hall Member Posts: 27,697
    I don't think you can point to any one specific thing. Lack of use certainly doesn't help, though. Mineral buildup on the ball, if it's not fully open, won't help — but periodic use should keep that to a minimum. On the other hand there are some chemicals — even additives in water, if in high enough concentrations — which can attack some seals materials. But I'm not sure you'd ever see concentrations high enough to be a problem in most of our work.
  • ChrisJ
    ChrisJ Member Posts: 17,622
    Letting them sit for years without being touched building up minerals etc
    Also rust / grit from steam boilers from my own experience.
    Use good valves and exercise them every 6 months and they'll outlast most people.
    Robert_H
    hot_rod Member Posts: 28,076
    seize up, break, leak??
    Misapplied, installation error, over-heating a sweat valve.
    Water quality, aggressive, high mineral content
    Fluid temperature, higher temperature, more minerals precipitate
    Lack of use
    Quality of valve construction, low quality alloy, thin forgings
    Manufacturers quality control
  • MaxMercy
    MaxMercy Member Posts: 624
    Getting OT, but can anyone recommend a specific brand and model of ball valve that will last more than 6 months on a well system with ~ 6.5ph water? The failure mode is the shaft inside the ball corrodes and the valve can't be turned fully on or off. The valve is right off the tank manifold so it's before the acid mitigation tank.
  • ChrisJ
    Curious if someone makes an inline valve like the stops I've seen that have a plastic shaft. They seem to hold up very well in general.
  • HydronicMike
    HydronicMike Member Posts: 411
    Not leaving them fully opened, or fully closed.
  • ScottSecor
    ScottSecor Member Posts: 1,053
    Of all the brands and models of ball valves we regularly use, I think the Apollo #77 are best. They do fail occasionally, but less than any other brand.
    As others have mentioned the following issues are problematic:
    Grit in system
    Lack of usage
    Heating systems with certain types of antifreeze
    Mad Dog_2SuperTech
  • Mad Dog_2
    Apollo...SS if water quality issues..Mad Dog
    MaxMercy
    Maybe a globe or gate valve is a better option. They are less prone to sticking. Exercise it a few times a year.
    Quality valves are easy to spot, thicker forging, packing nut. Apollo Watts, Nibco still build some better valves in the US.
    Jomar has a quality Italian valve line.
  • jumper
    Exercise shut off annually? I try to remember to do them each leap year.
    reggiPC7060
    The more you work it , the better the chance of it working when you need it.
    The Caleffi LegioMix is a ball type mixing valve and once a day it rotates all the way around, to wipe scale off.
    LOL @jumper
    "Too much use or lack of exercise"
    Sounds like my Doctor talking about me!!!
    PC7060
  • 4GenPlumber
    4GenPlumber Member Posts: 176
    If the problem is acidic water, go with a rising stem gate valve. NIBCO still makes them. Still have to work them though.
    MaxMercy
    valves used on potable water need to be LL, low lead. It will be dezincified brass also, so they are better alloys for low ph water.
    Stainless or plastic valves are an option. Plastic would be most tolerant. Maybe a schedule 80 quality pvc gate valve?
  • Intplm.
    Intplm. Member Posts: 3,130
    What @hot_rod says above.
    And this type of valve works best with corrosive water issues.
    Another option. This is fiberglass reinforced plastic, super easy to disassemble and
    clean.
    Intplm.
