A Good Laugh
Hey...bathroom is warm...mission accomplished! Mad Dog
A different kind of "upper decker" 😈
3 -
All well and good but did they use the Haydon 750P for corrosion resistance in that location?
I always thought that adding the Letter P to the 750 model number was a significant statement for that brand of baseboard. Lets you know exactly why you should use it in the bathroom!
2 -
i did that for like 5' at the end in my shop in the basement because the heat loss said i needed that much more that I had wall. what I didn't know at that time was that the higher entering temp lowers the output of the upper section. so i guess i needed to continue it another 5' around the corner…
Next time do it this way…. same air inlet temperature so the same output.
You can tell that I have nothing better to do with this last illustration.
3 -
Looks like Sterling Kompak on top the bottom one looks like a different brand, so they are all mangled up Not only did they double it up he piped the fin tube without checking how the covers fit.
Was that Columbus, Ohio?
For what's it's worth, I have a baseboard cabinet in the kitchen where they JAMMED in two 3/4" finned elements in parallel to get more heat. The fins are mashed up a bit and don't know if the air flow through this mess actually adds more heat that a single high output section installed correctly.
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
