Green patina/corrosion on copper pipes = replace?
Then I read stuff that says that “patina” will not eat through the pipes to cause a problem, or would take forever to do so, or even that it protects the pipe! If I don’t replace these I can just clean them (probably either ketchup or catsup, depending, and mesh tape). The pipes are decades old, and there are more, some less accessible than these. See photos.
You don't have a problem. There might be a tiny weep responsible for the last picture, but otherwise... I'd say most of what I see is from flux that never got fully wiped off. Leave them be.Br. Jamie, osb
All the flux and solder buggers on the inside will eat the pipes before the patina on the outside. It's a good idea to clean it up so you can see if you have a leak. The patina itself should not cause any issues."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
@Jamie Hall and @Zman, regarding your helpful observations I will use an old venerable plumbing term(?): Yay!0
Probably a small seep on the uppermost fitting. It may have sealed itself off?
If it were flux, you would see it in more places.
I’d wonder if the tube was reamed, judging by the workmanshipBob "hot rod" Rohr
Its the white, crusty condition you have to watch. The inside of the pipe is usually green like that from Chlorination...par for the course...no concern. Normal weather will turn Exposed Copper green outdoors. When you see the crusty, white stuff effervescence?? then you gave a gradual weeping leak that will get worse. Cut that out...Always make sure all Flux is off the pipe & fitting. Mad Dog 🐕0
@Mad Dog_2 I've been away from the forum for a while. Your breakdown into the two conditions is VERY helpful (I have both on some fixtures). I am in Plumbing 1 now and have signed up for Plumbing 2 at the local BOCES. Am also thinking of going to a couple of one-day classes on burner stuff given by Beckett up in Mass. (I'm about to start a new thread asking if anyone knows about those.)0
Very nice pieces, wonder what they’ll fetch on the art market.0
I have similar stuff building up where I connected copper pipe to my stainless manifold 6 years ago.
So it is not galvanic corrosion? Should I do something about it?0 -
It looks like that threaded connection had a small seep for a period of time. Perhaps sealed itself, if it stays dry?
Often times the seep reappears when the system cools down over the summer, the contraction of the various metals.
Also a lot of the imported manifolds have a thread NPTF that differs a slight amount from the tapered NPT threads used in the U.S.
The DN 25, a metric sizing term, (diameter nominal) and short socket length, can be the giveaway.
So that threaded connection can be more challenging to seal. It is usually best to do a connection like that with a Loctite type sealant, basically gluing the two parts together.
You could wire brush it, but the leak may reappear if you do.
Thanks. It seems dry, but I will keep an eye on it.
- 15.8K Strictly Steam
