Steam heat uneven between our two floors of 150 y.o. home
The past several months, the heat on our second floor has been 2-3 degrees cooler than the heat on our first floor. I wonder if it might be an issue with my pressure not being sustained to push the heat to the 2nd floor in our 1-pipe system, if so, I don't know how to change that? If not, what might it be? Thank you for your assistance.
    pecmsg Member Posts: 7,024
    pressure has nothing to do with it.
    venting does.
    ethicalpaulIronmanmattmia2
  • neilc
    neilc Member Posts: 3,164
    was it working better last year?
    has anyone been out to service the boiler? tuneup? any other work done?
    we'll get around to asking to see the boiler, post a couple shots floor to ceiling, opposing angles, post a shot of the controls side, Ptrol and siteglass, what pressure do you see when the boiler is running a while?
    known to beat dead horses
  • Ironman
    Ironman Member Posts: 7,902
    Increasing pressure will not fix the problem and will probably create other issues. A one pipe system should never be set above 2 psi.
    As mentioned, it’s most likely a venting issue.
    Bob Boan
