Steam heat uneven between our two floors of 150 y.o. home
The past several months, the heat on our second floor has been 2-3 degrees cooler than the heat on our first floor. I wonder if it might be an issue with my pressure not being sustained to push the heat to the 2nd floor in our 1-pipe system, if so, I don't know how to change that? If not, what might it be? Thank you for your assistance.
was it working better last year?
has anyone been out to service the boiler? tuneup? any other work done?
we'll get around to asking to see the boiler, post a couple shots floor to ceiling, opposing angles, post a shot of the controls side, Ptrol and siteglass, what pressure do you see when the boiler is running a while?
known to beat dead horses0 -
