Steam Near Boiler Piping
            I always have a hot dust smell at the first or second run at the beginning of the heating season. Is the hot oil haze coming out of the vents ? Maybe take a step back and do a bunch of skimming. National - U.S. Gas Boiler 45+ Years Old
 One Pipe System0
            make up is there. Image below. Yes, more skimming for sure. It’s bouncing all over the place. I want to get it up and check for leaks (none yet) then I’ll let it cool a bit and skim some more tonight and tomorrow. And then maybe again here and there through the week. My assumption is the oils in the pipes from cutting will be coming back to the boiler eventually. 0
            " Not seeing a makeup water valve, usually it is kind of close to the boiler. " Still not seeing the Valve. National - U.S. Gas Boiler 45+ Years Old
 One Pipe System0
            I looked up the Utica skimming instructions, and they don't mention adding some washing soda or TSP substitute like some manufacturers do. I found it cuts the oil and makes skimming far easier and shorter process. Run some of that detergent in the boiler for a short while and then skim. Nice install! I am also a little curious where the makeup water valve is 😅 NJ Steam Homeowner.
 See my sight glass boiler videos: https://bit.ly/3sZW1el0
            the valve to make up water is located above and behind the boiler on the wall. Where it was when I bought the house. I intend to relocate it to the copper pipe on the return leg when I drain it down next. Is that what you were looking for or am I misunderstanding. Picture is grainy but it is there. 1
            if you skim a little bit more often you can keep from throwing as much of the oil out in to the system and there will be less to work its way back. 0
            i would keep both valves either way, give you more options when the one near the boiler fails. 0
            With respect to the valve I am going to keep the original and add a second near the boiler. Keeping it will allow me to add the second without draining down the system. The second valve will make service at the boiler that much easier. Having to monitor while operating the valve where it is located is a pain. I am going to keep on skimming. I did not add TSP or another detergent as I wanted to stick with the manufacturers instructions. If this does not get noticeably better over the next week or so I will deviate. The haze went away finally after a few hours. 0
            I'm going with sloppy work using a hatchet / axe etc. I highly doubt steam or anything else did that, unless there's actual rott / soft wood in the area. Even then I still think someone hacked it out to clear the steam piping before it was finished. Fire woud've left black / charcoaled wood. Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times. 0
            Not sure how a hatchet / axe etc. would char the wood, I thought the OP said it was charred, looks charred to me in some of the pictures directly above the boiler. National - U.S. Gas Boiler 45+ Years Old
 One Pipe System0
            I missed that. But honestly, the pictures don't show it good enough IMO. It's hard to tell. But yeah, you're right, steam didn't do that nor did the piping unless something went horribly wrong. Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times. 0
            There was a really bad fire in my town yeas ago which was a total loss. The local FD blamed the steam system saying the steam pipes rested on wood and charred the wood. They claim that when the wood gets charred its ignition point is reduced. I was skeptical back then and still am. I think if that was true there would be few steam heated houses standing 1
            I generally find it's harder to light charcoal than wood. From my own experience I'd argue it's harder. But the only experience I have from steam piping touching wood is it often tends to produce expansion noises. I've certainly never seen any darkening or anything, and all of my steam radiators are sitting on wood floors. Those cast iron feet aren't exactly cool. Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times. 0
            The ignition point is reduced to 212 degrees LOLOL NJ Steam Homeowner.
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
