I'm getting solar panels. I'll let you know how it goes in this discussion thread.
2»
  • SlamDunk
    SlamDunk Member Posts: 1,761
    edited July 17
    Solar is the way to go if you can. I looked at the sunpower website many years go and I had an ideal, shallow roof facing south. But my neighbothood of single story bungalows is being turned into a neighborhood of mega mansions with no yards. The mandatory 15' setbacks have been reduced to 5', so I decided against it. No neighboring houses have changed but my neighbor's wax myrtle privacy screen grew and has shaded atleast 20% of my roof so I'm glad I didnt waste the money. But, maybe the shade helps reduce my cooling bill. Good luck with your project!
  • jumper
    jumper Member Posts: 2,468
    Net meter is economically crazy. Obviously. Distribution and delivery is often way more costly than energy. Eventually PUC must renege (change rules) or continue to cheat paying customers.
    If I was likely to keep home in family for decades I'd buy solar and keep it independent from grid. Use output for thermal storage. Economics of batteries depend on longevity. Longevity is more important than efficiency. Unless prices go down.
    Jamie Hall Member Posts: 26,231
    True — distribution costs are a goodly chunk of the bill. However, there is an interesting problem relating to how to charge for (or recover the cost of) the power production part of the equation. Just how much is a kilowatt-hour of energy cost? What do you include in the cost? Just using the system which we have installed, depending on how you figure such things as depreciation, cost of land, maintenance, etc., a very good argument can be made that a kilowatt-hour from our array is worth between $0.27 and $0.35 in today's money. Should the power company pay the owner of the array that? As it happens, that is what the power company in our area effectively pays under 1:1 net metering.
    But determining the actual value of a kilowatt-hour of power from any given PV array would be a rather difficult computation…
    Now to make things even more messy, other power sources have other costs, some of which are difficult to quantify (the environmental impact of hydroelectric is notoriously hard to quantify).
    But… on the other hand, one can also argue (reasonably) that distribution, then, is not being adequately funded (in my view, it isn't) and that electric rates should, in fact, be considerably higher to pay for maintaining and upgrading the distribution grid system. Not, I might point out, a politically popular point of view…
  • OffGridICF
    OffGridICF Member Posts: 12
    Battery prices have definitely come down. I bought LiFePO4 battery cells along with battery management systems direct from a reputable seller in China in 2021. At that time, it was a lot less expensive to buy the components and build my own battery bank. Since then, the prices for the same LF280K cells have dropped to less than half of what I paid including free 5 day delivery from the US. These cells are rated to only drop to 80% of their new capacity after 6000 cycles or 10 years, whichever comes first. Now you can get 8000 cycle cells for not much more money but I think they are still 10 year cells. I expect mine to fade due to calendar aging rather than cycle aging but still be useful past 10 years. Heat is probably the biggest factor in battery life for these cells so I try to keep them from getting too hot. In general, they also need to be kept above freezing during charging and heavy discharging to avoid permanent damage.
    mattmia2 Member Posts: 13,734
    edited July 18
    the energy you generate is likely being used locally, it doesn't use much of the distribution system and it requires less of the higher up parts of the distribution system be used.
    i'd argue that the condition of the grid is the mismanagement of the utility they gave money that they did not have to their shareholders, it was money that they needed to use to maintain the infrastructure that makes them money. i see it as no different than taking out a loan, giving it to their shareholders then expecting the customers to repay the loan. in my area they have owned the infrastructure for over 100 years. the sate it is in is their responsibility.
    edit: and you complained about my comment about the ai fiction that said tempered glass could crack rather than shatter.
    either your post is going to drift in all sorts of directions or it is going to rocket to page 2 and beyond to never be seen again
    ethicalpaul Member Posts: 7,788
    1:1 net metering isn’t sustainable. In solar-mature states it has been ended—even California!
    But on the East coast we still have it for now and we get locked in for a number of years.
    My personal opinion is that 1:1 was a very good idea to get systems installed to kick start a business that will be and is a major part of our energy supply.
    I didn’t mind your post, Matt, except I don’t get hail
  • Intplm.
    Intplm. Member Posts: 2,702
    @ethicalpaul What, if anything, does the solar company say about your roof that will hold the panels? Do they take any responsibility for roof repairs? Was the roof assessed before installation? Is there any language in the contract that concerns the roof?
    installation hasn’t happened yet. They have been out once so far to look at the support structure of the house frame.
    During the quote process I sent them photos of the attic and the floor plans.
    Since this roof supported 2 layers of shingles for about 30 years and now has one layer, and since it’s built with old growth pine with old, larger dimensions that is very strong I personally am not worried about it.
    Panels weigh like 3 pounds per sq ft. My understanding is that roofs are expected to be able to carry 20 pounds per sq ft of snow without stress.
    Intplm.
    Without 1;1 net metering, the PV array we installed would not have been cost effective — and we wouldn't have done it.
    For what it's worth, the net return on capital invested in a power company — as it might be your local utility — is around 4% at last count. It's quite possibly one of the worst investments one could make with one's money. Not that I am a financial advisor — far from it — but at that rate of return, the power companies simply cannot attract the investment required to maintain the distribution system, even locally, never mind upgrade.
    My power company seems to maintain its distribution system quite well.
    So does mine — but they cant replace aging components, nor upgrade it. It's purely reactive, not proactive.
    Intplm.
    edited July 18
    Strange how we are using much more electricity than ever before, yet the lights stay on! I guess they are reacting pretty well! Is it possible they might in fact be doing a little proactive planning and engineering?
    Hot_water_fan
  • ChrisJ
    ChrisJ Member Posts: 16,873
    With how much NJ has grown, all I've seen is more and more transmission lines run etc.
    My power goes out for a short time maybe once every 5 years. I still haven't been able to actually use the NG generator I built 5 years ago.
    All I ever see is JCP&L and PSE&G upgrading and replacing equipment.
    There's always the chance it's not the same everywhere. Also, they just increased everyone's electric bill by 20%, so maybe that's part of it too.
    ok gang— the permits all cleared (state, utility, and town) and the solar install crew is coming early tomorrow morning so expect some more posts with photos
    mattmia2EBEBRATT-Edhot_rodHot_water_fan
    hot_rod Member Posts: 25,432
    Here is what 6200W did for my place.
    Screenshot 2025-08-04 at 8.39.34 PM.png Screenshot 2025-08-04 at 8.38.48 PM.png
    ethicalpaulIn_New_England
    they got here at 7am. They first had to verify some roof measurements and layout.
    then I helped them locate the first rafter (from the attic) because the “hit the roof with a mallet” method wasn’t working very well because my decking is solid 1915 pine tongue and groove.
    They expect to be done with the installation today
    GGrossIn_New_England
    10:30am progress
    ChrisJIn_New_England
  • PC7060
    PC7060 Member Posts: 1,705
    edited August 5
    Pretty house, like your flower boxes. Keeping the upper level window boxes water have proven to be a challenge for us. 😉
    ethicalpaulChrisJAlan (California Radiant) ForbesIn_New_England
    I ran an irrigation line up there which worked pretty well, but even with it, the plants up there get absolutely blasted by the sun all afternoon, so what's up there now is fake plants!
    PC7060Alan (California Radiant) ForbesIn_New_England
  • ChrisJ
    If it's anything like my house, finding the first rafter is almost irrelevant.
    You'd need to measure every one of them inside, make a drawing and use that because there's nothing consistent. For example, my floor joists, some are 23" OC, some are 24, some are 25, 26 etc. They're all over. Kinda, "hurry up good enough" style.
    I guess the actual distance was far less important before plywood and drywall.
    PC7060ethicalpaulDCContrarian
    yes mine vary between 20” and 22” on center. But the racks can span several rafters so we don’t have to locate each one
    sounds like you may need some seismic restraints back there?
    If there is access to the underside of the roof, we found it easier to miss the rafter and block across two of them and anchor to the block. Finding dead center of a rafter from above is not so easy as you may have discovered.
    This was for thermal collectors, fewer mounts required.
    ethicalpaulAlan (California Radiant) Forbes
    Is that thing that looks like roof jacks and planks actually the bottom rail?
    I think it is.
    My wife and I felt the 3.0 quake on Saturday night, but there was a 2.5 one today that I didn't notice
  • neilc
    neilc Member Posts: 3,032
    you have a venison problem
    known to beat dead horses
    mattmia2ethicalpaulJoannie
  • neilc
    those are some funny looking dogs
    Joannie
    edited August 6
    is that some sort of uhf or microwave antenna on the tripod near the gable?
    mattmia2OffGridICF
    ethicalpaulPC7060OffGridICF
    guess we don’t live in HOAs 😂
    mattmia2OffGridICFCLamb
  • ChrisJ
    If I was in charge of an HOA and someone wanted an armature radio antenna I'd require a decent tower and a reasonably sized yagi. None of this cheesy roof tripod stuff. 😉
    DCContrarianethicalpaulPC7060
    luckily you’re not I guess because that tripod is holding up a wire antenna not a yagi
  • fentonc
    fentonc Member Posts: 312
    @ethicalpaul - re: "About the same price as a boiler install" - I'm over in NY, but probably not too far, and my 5KW array (after incentives) was a little cheaper than the boiler I had installed the year before. The array has continued to average around 500 kwh/month for the last 7 years (+/- 10% based on weather), which, as electricity prices have come close to doubling in the last 7 years, has had a substantially better financial return than my boiler.
  • Intplm.
    @ethicalpaul Hope you will post a few things as to how the system benefits you in the future.
    You have a good-looking house. Even the deer are admiring it.
    mattmia2ethicalpaulIn_New_England
    Thank you, I sure will post the good, bad, and the ugly. No word yet on the inspections. Waiting on the town I think.
