Old fridge
I know some folks are into this stuff… This came through FB marketplace.
Marketplace - 1932 Antique GE Refrigerator | Facebook
ChrisJ
«13
    mattmia2 Member Posts: 17,904
    not as hard to move as they make it out to be but you do need to take the cooling unit off to move it and make a frame out of wood or something to hold the cooling unit for transportation.
    pecmsg Member Posts: 7,441
    use extreme caution moving that system. Probably SO2 Sulfur Dioxide as the refrigerant. You Do Not want a leak indoors.
    Mad Dog_2
    Where's @ChrisJ ???
    ChrisJmattmia2Intplm.
    he'll know which ones where SO2, which ones were methyl formate, and which ones were Freon 12. I think only the earliest ones were SO2.
  • ChrisJ
    ChrisJ Member Posts: 17,622
    edited May 2025
    That's a 1933 CA-2-A16 machine.
    It uses methyl formate which behaves very similar to R-11 so the system is actually in a vacuum when not running. The evaporator goes into a very deep vacuum when running and even the condenser may stay in a slight vacuum.
    The top comes off and isn't held on by anything other than gravity. You should remove it or strap it on with ratchet straps.
    Be very careful removing and installing the top as the copper lines are very close to the lip on the cabinet and many machines get damaged this way.
    If anyone buys it and needs help with it please let me know. We have a forum dedicated to these at
    mattmia2PC7060delcrossv
  • ChrisJ
    edited May 2025
    1927-1932 and then again 1935 - 1940s were SO2
    Only 33-34 were methyl formate. Some later were allegedly R12 but I've never seen one.
    I have both methyl formate and SO2 machines. Both have pros and cons.
    mattmia2PC7060EBEBRATT-Edkcopp
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,716
    Didn't some of them contain ammonia? Mad Dog
    Domestic mechanical systems, at least mass produced systems, never used ammonia. Absorption systems use ammonia which were used a few domestic systems, especially ones designed to run off of kerosene or propane in areas without electricity although there were a few gas or electric systems marketed for general use. Absorption refrigerators are still common in RVs where they can run off of both propane or electricity depending on what is available. Many large commercial systems used ammonia.
    pecmsgMad Dog_2
    Steamhead Member Posts: 18,805
    Consulting
    mattmia2delcrossv
    it was the main company that made the domestic absorption refrigerators.
  • ChrisJ
    Mad Dog_2
    EBEBRATT-Ed Member Posts: 20,833
    They had/have gas fired absorption system for household refrigeration. My grandfather had one back in the early 70s they were still using on natural gas that was probably made in the 30s or 40s.
    They used ammonia
    Don't they still use them in trailers and campers?
    Bar I worked at back in the early 70s had Servel absorption units that cooled the place. The gas utility used to push those so they had more gas usage in the summer.
    Servel was taken over and is now called "Rober" or "Roper"? They were still in business the last I knew.
    edited May 2025
    I actually installed two of these back in the 90s. Funny story about that but for another day.
    ratio
  • delcrossv
    delcrossv Member Posts: 2,204
  • MaxMercy
    MaxMercy Member Posts: 624
    OT a bit (and I have two questions at the end), but I have a post war GE that's been running continuously for almost 80 years. The only way I know it's running is because it's always 34F inside..
    These old refrigerators are plentiful as they still toil away in basements for overflow or man-cave beer duty while the fancy stainless pile of garbage upstairs gets replaced every 2-5 years - they're all over FB Marketplace and most of them still run.
    Talk about a big middle finger to modern "quality". In an age where Chinese compressors struggle to last 5 years, these old motors/compressors run for decades.
    Questions: what refrigerant would a 1948 GE use? Also, some guy on youtube allegedly ran an old refrigerator through a wattmeter and he claims it uses no more power than modern ones, at least not significantly. We were told to scrap these even if running because a new refrigerator would pay for itself in energy savings in short order. Are these power hogs as we were told or are they actually close to the efficiency of a modern refrigerator?
    delcrossvkcopp
  • ChrisJ
    edited May 2025
    I think the video you're talking about is from a guy named Dusty? He knows his stuff.
    I don't know much about 1948 stuff, but I'd guess R12 or similar on something that modern.
    No, the really old refrigerators never were energy hogs.
    I've had a 1933 GE Monitor Top running in my kitchen for 10 years now and it averages around 30kwh a month running 33-34F. Right next to it is a 1935 GE Ball top which has been running for 4 years, that runs about 18kwh a month and it's used and opened constantly. Most of the mid to late 1930s - 1940s machines use very little power, 1935 is when GE really perfected things. There's usually no fans, and no defrost heaters etc. For what it's worth, we have a 2022 manual defrost mini fridge in the office that uses 20kwh a month, according to energy star but I've never measured it.
    Here's the other problem.
    What about more modern refrigerators that are "Energy hogs"? I'm picturing 1960s-80s side by side refrigerators etc. What's it going to cost to run, $10-12 a month? The most you're going to save is a few dollars a month at best even replacing a so called hog. Replacing a 1930s-40s refrigerator with new will pretty much always result in quite a bit more power consumption unless something was really wrong with the old one.
    delcrossvMaxMercy
    ethicalpaul Member Posts: 8,978
    edited May 2025
    Designed, specified, ordered, and approved by US companies. Let's take some responsibility shall we?
    Except when you factor in the energy and time required to defrost them. Isn't the majority of energy used by modern refrigerators due to the defrost cycles?
  • winnie
    winnie Member Posts: 79
    This is not research, this is a google result that I need to explore further to properly understand its context. But I'm not sure I will have the time. The claim made by the figure is that per unit energy use was at its worst in the mid 1970's, and that a 1950 refrigerator used less energy than a 2002 refrigerator. The 2002 refrigerator was some 2x the volume for similar energy use, and probably has automatic defrost, ice maker, etc. included in its energy use.
    Taken at face value, if you have a fridge from 1950 you take a small energy hit to keep it running, but if you have a fridge from 1975 you should replace it because the efficiency is so horrible.
    https://www.researchgate.net/figure/US-refrigerator-energy-use-between-1947-2002-Mid-1950s-models-consumed-the-same_fig1_317751623
  • ChrisJ
    edited May 2025
    On any 1930s and up GE you turn the knob to defrost and go to bed. When you wake up you dump the tray of ice and water into the sink.
    It keeps running to maintain temperature but it raises the turn on point above freezing so the frost falls off.
    How much time and energy are you going to factor in for that? It's zero energy.....
    Regardless,
    The efficiency of the refrigeration equipment hasn't changed. The insulation of the cabinet hasn't improved.
    And like I said, even the much later ones that do use a lot of power, it's not enough to justify replacing it.
    ethicalpauldelcrossv
    The quality problem isn't with the compressor, it is with the tubing. it leaks the refrigerant out.
  • ChrisJ
    edited May 2025
    That's only with your dehumidifiers. Not really, but.
    There's plenty of problems with compressors.
    And Ice makers and all kinds of other fun.
    tubing that was designed, specified, ordered, and accepted by American companies. I hope my point is discernible
    Thanks for that info, I didn't know they made it easier at some point. I've only seen your photos of a pan of hot water and a propped open door 😅
    Frost free is where you lose efficiency. The insulation on a modern fridge is far better than on a fridge from the early 80's or earlier but heating it up to defrost then removing that heat uses a lot of energy.
    You will never make up the difference in cost of energy consumption between a 60's frost free fridge and a modern fridge before the refrigerant escapes from most modern fridges.
    In to the early 70's frost free fridges had a timer that ran all the time and ran the defrost cycle every x hours. Newer fridges run the defrost timer only when the compressor is running so it runs it on hours of compressor operation. In the last 25 years or so they have got electronic controls that sense temps of various parts and only run a defrost cycle when necessary.
    Closed cell foam insulation on a modern fridge has a higher r value, over the past 20 years or so has become much thicker, and doesn't absorb moisture and both become ineffective and waterlogged if there is an air leak in the cabinet like fiberglass will.
  • ChrisJ
    Sometimes I use an icecube tray with lid and hot water.
    Sometimes I use a ziplock bag full of hot water.
    I've never propped a door open, not once so I have no idea where you're getting that from. It's full of food that I don't want getting warm.
    Even my 1933 has the defrost option. I'm just too impatient to use it so I use the method I mentioned above twice a year.
    I don't think it meets the specification that was ordered. I'm not saying that the distributors in the us aren't responsible for the quality of what they distribute but they aren't getting what they ordered.
  • ChrisJ
    delcrossv
    I'm pretty sure when Whirlpool or Frigidaire or whoever is about to ship millions of refrigerators around the world from their manufacturing plants, they do some testing and certification of some of them to make sure they're getting what they asked for.
    And if they didn't, well that's still on them. You have to verify you're getting what you ordered whether you're a homeowner, a manufacturer, or anyone.
    Thanks again! Maybe you had it propped open to take the photo 😊
    It isn't so much that they made it easier, it is that the freezer compartment is so tiny compared to even a 50's fridge that it doesn't take long for the ice to melt. The defrost setting wouldn't work on a freezer compartment that was large enough to be useful.
    That's cool. Should I figure out how to rewire mine so that the defrost is manual? Then I'd have modern insulation and features that I like and not have that wasteful auto-defrost
  • ChrisJ
    ethicalpaulPC7060
  • ChrisJ
    @mattmia2 For what it's worth, any freezer ever made doesn't take long to defrost if you do it when you're supposed to. I get by doing it twice a year thanks to air conditioning etc, but the book recommends once a month.
    If you've got 5 years of ice built up, it's going to take a while and make a huge mess.
    I only have one freezer so it can only happen when it is cold enough out for the food to take a vacation in my garage. I think it had been a couple years.
    the heating it to defrost then having to remove that heat is the part that uses energy. You would have to have a manual defrost cold wall type appliance to avoid that energy usage.
  • ChrisJ
    If anyone actually cared about energy consumption refrigerators would reverse and defrost via heatpump. They would also be substantially smaller. But, it's not about that, it's about moving product.
    @ethicalpaul Your modern insulation isn't any better than what's in a Monitor Top. It's only corrugated cardboard but it's 3" thick which has a fairly decent R value. Very similar to 3" of fiberglass.
  • winnie
    And when you wait a few decades to defrost your cold storage building….
    https://youtu.be/9_iPcqfjX0Y?si=YK8rLR_yMXDWsrgA
  • ChrisJ
