Flow exhaust or pump exhaust, which is better for a hot water tank?
fuel type?
Gas
Liner exhaust or pump exhaust?
Sorry but …we do not understand the terminology Flow exhaust,Pump exhaust,Liner Exhaust or Exhaust pump tank.
Can you post some pictures of the equipment in question
Make and Model #'s?
That is the conclusion I slowly reached…
Trying to keep Bernie burning!
Are you asking if a fan is needed? Is it better? Or is a common draft better? It depends on what you are using it with. Please post some pictures or at least be a little more specific in your description.
- 15.8K Strictly Steam
