Flow exhaust or pump exhaust, which is better for a hot water tank?
bdp1999
bdp1999 Member Posts: 60
Currently i have a flow exhaust but no chimney liner, would you recommend getting a liner or just going with an exhaust pump tank?
    EBEBRATT-Ed Member Posts: 20,044
    ???? Don't know what you mean.
    mattmia2Intplm.Ironman
    Jamie Hall Member Posts: 27,188
    fuel type?
  • bdp1999
    Gas
  • bdp1999
    Liner exhaust or pump exhaust?
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Sorry but …we do not understand the terminology Flow exhaust,Pump exhaust,Liner Exhaust or Exhaust pump tank.
    Can you post some pictures of the equipment in question
    pecmsg Member Posts: 7,006
    Make and Model #'s?
    hot_rod Member Posts: 27,260
    Do you mean a regular chimney type vent, either masonry or metal, compared to a power (fan assist) vent type?
    Ironman
  • Bernie_the_Brewer
    Bernie_the_Brewer Member Posts: 28
    Trying to keep Bernie burning!
  • Intplm.
    Intplm. Member Posts: 2,981
    Are you asking if a fan is needed? Is it better? Or is a common draft better? It depends on what you are using it with. Please post some pictures or at least be a little more specific in your description.
